PSA.3S.250.CTLC11
PSA.3S.250.CTLC11
    LEMO(雷莫)
    PSA.3S.250.CTLC11
PSA.3S.250.CTLC11 数据手册
PSA.3S.250.CTLC11 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 3S Termination type Female solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 9.80 - 10.50 mm Status active Matching parts FFA.3S.250.CTAC11 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PSA*: Fixed receptacle, nut fixing, cable collet Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 55.92 g Performance Configuration 3S.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 26 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 3 mm (0.118in) Bucket Dia.: 2.7 mm (0.106in) Vtest: 3000 V (AC), 4200 V (DC) Impedance: 50 Ohm VSWR: 1.06 + 0.5 * f/GHz Cable type: RG 213/U, RG 115 A/U, RG 11 A/U, RG 144/U, RG 165 /U LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A B E L M S1 S2 S3 e mm. 22 25.2 11.5 59 2 16.5 14 22 M18x1.0 in. 0,87 0,99 0,45 2,32 0,08 0,65 0,55 0,87 RECOMMENDED BY LEMO Tools Spanner wrench: DCP.91.023.TN LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 213000 PE Black 311100 PVC Black CCX.50.RG2.13U10N PE Black CCX.75.RG0.11AU10N PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PSA.3S.250.CTLC11
物料型号:PSA.3S.250.CTLC11
器件简介:LEMO公司生产的固定插座,采用螺母固定,电缆卡箍。
引脚分配:1个同轴电缆接口。
参数特性: - 系列:3S - 端接类型:女性焊接同轴 - IP等级:50 - 电线尺寸:AWG,直径9.80 - 10.50 mm - 状态:活跃 - 匹配零件:FFA.3S.250.CTAC11
功能详解: - 配置:3S.250,1个50欧姆同轴(焊接) - 绝缘体:PTFE - 额定电流:26安培 - 接触类型:50欧姆同轴(焊接) - 接触直径:3毫米 - 桶直径:2.7毫米 - 电压测试:3000伏交流,4200伏直流 - 阻抗:50欧姆 - VSWR:1.06 + 0.5 f/GHz - 电缆类型:RG 213/U, RG 115 A/U, RG 11 A/U, RG 144/U, RG 165 /U
应用信息: - 耐久性:5000次配对周期 - 温度范围:-55°C至+250°C - 湿度:最高95%(在60°C/140°F时) - 振动:15 g(10 Hz - 2000 Hz) - 抗冲击性:100 g(6 ms) - 气候类别:50/175/21 - 屏蔽效能:最小75 dB(10 MHz),最小40 dB(1 GHz) - 盐雾腐蚀:>144小时
封装信息:提供了详细的尺寸图纸和推荐使用的工具和电缆。
PSA.3S.250.CTLC11 价格&库存
很抱歉,暂时无法提供与“PSA.3S.250.CTLC11”相匹配的价格&库存,您可以联系我们找货
