ERA.3S.650.CTL
ERA.3S.650.CTL
    LEMO(雷莫)
    ERA.3S.650.CTL
ERA.3S.650.CTL 数据手册
ERA.3S.650.CTL www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 3S Termination type Female solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFA.3S.650.CTAC10 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ERA*: Fixed receptacle, nut fixing Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 27.78 g Performance Configuration 3S.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 15 Amps Specifications Contact Type: Triaxial 50 Ohm (Solder) Contact Dia.: 2 mm (0.079in) Vtest: 1200 V (AC), 1700 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.27 * f/GHz Cable type: Belden 9222,8215,8232A,HF-2426,Triax 8 Nokia,375 029 LEDE, Belden 9267 Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M S1 S3 e mm. 22 25.1 10.6 32 2 16.5 22 M18x1.0 in. 0,87 0,99 0,42 1,26 0,08 0,65 0,87 RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.65.200.AZ LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ERA.3S.650.CTL 价格&库存
很抱歉,暂时无法提供与“ERA.3S.650.CTL”相匹配的价格&库存,您可以联系我们找货
