FFA.2E.675.CTAC85Z
FFA.2E.675.CTAC85Z
    LEMO(雷莫)
    FFA.2E.675.CTAC85Z
FFA.2E.675.CTAC85Z 数据手册
FFA.2E.675.CTAC85Z www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 2E Termination type Male solder IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 8.10 - 8.50 mm Status active Matching parts ERA.2E.675.CLL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet and nut for fitting a bend relief Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 42.11 g Performance Configuration 2E.675 : 1 Triax (75 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Contact Type: Triaxial 75 Ohm (Solder) Contact Dia.: 0.9 mm (0.035in) Vtest: 1200 V (AC), 1690 V (DC) Impedance: 75 Ohm VSWR: 1.02 + 0.07 * f/GHz Cable type: Belden 8215,8232A,HF-2426,Triax 8 Nokia,375 029 LEDE, RGT 179 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S2 mm. 16 52 36 12 in. 0,63 2,05 1,42 0,47 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.2E.ZZZ.PA120 Caps: BFA.2E.100.NAS LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.2E.675.CTAC85Z
物料型号:FFA.2E.675.CTAC85Z
器件简介:LEMO公司生产的三同轴电缆连接器,适用于需要高屏蔽效果和高电流容量的应用。
引脚分配:1个Triax(三同轴)引脚,用于75欧姆的信号传输。
参数特性: - 额定电流:6安培 - 接触类型:三同轴75欧姆(焊接) - 接触直径:0.9毫米 - 电压测试:1200伏交流电,1690伏直流电 - 阻抗:75欧姆 - VSWR(电压驻波比):1.02 + 0.07 f/GHz - 适用电缆类型:Belden 8215,8232A,HF-2426,Triax 8 Nokia,375 029 LEDE, RGT 179
功能详解: - 端子类型:FFA,直插头,电缆固定套和螺母用于安装弯曲缓解装置 - 键槽:圆形,男性 - 外壳材料:黄铜(镀铬[SAE AMS 2460])壳体和固定螺母,镍镀[SAE AMS QQ N 290]黄铜锁紧套和中间件 - 变体:Z,用于安装弯曲缓解装置的螺母
应用信息: - 耐久性:5000次配对周期 - 温度范围:-55°C至+200°C - 湿度:最高95%(在60°C/140°F时) - 振动:15g(10Hz至2000Hz) - 抗冲击性:100g(6ms) - 气候类别:50/175/21 - 屏蔽效果:最小95dB(10MHz),最小80dB(1GHz) - 盐雾腐蚀:>1000小时
封装信息: - 重量:42.11克 - 尺寸:A(16mm / 0.63in)、L(52mm / 2.05in)、M(36mm / 1.42in)、S2(12mm / 0.47in)
FFA.2E.675.CTAC85Z 价格&库存
很抱歉,暂时无法提供与“FFA.2E.675.CTAC85Z”相匹配的价格&库存,您可以联系我们找货
