FFA.2E.650.CTAC75
FFA.2E.650.CTAC75
    LEMO(雷莫)
    FFA.2E.650.CTAC75
FFA.2E.650.CTAC75 数据手册
FFA.2E.650.CTAC75 www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 2E Termination type Male solder IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 7.10 - 7.50 mm Status active Matching parts ERA.2E.650.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 41.14 g Performance Configuration 2E.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 12 Amps Specifications Contact Type: Solder Vtest: 1200 V (AC), 1690 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.3 * f/GHz Cable type: RGT 174,Belden 9222,8215,8232A,HF-2426,Triax 8 Nokia,375 029 LEDE Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S2 mm. 16 52 36 12 in. 0,63 2,05 1,42 0,47 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.2E.ZZZ.PA120 Caps: BFA.2E.100.NAS LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.2E.650.CTAC75 价格&库存
很抱歉,暂时无法提供与“FFA.2E.650.CTAC75”相匹配的价格&库存,您可以联系我们找货
