FFA.2E.675.CTAC65
www.lemo.com
SUMMARY
# Wires
Triax
1
Image is for illustrative purpose only
Series
2E
Termination type
Male solder
IP rating
68 when mated
AWG wire size
0.00 - 0.00
Cable Ø
6.10 - 6.50 mm
Status
active
Matching parts
ERA.2E.675.CLL
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FFA*: Straight plug, cable collet
Keying
Circular, male
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
41.65 g
Performance
Configuration
2E.675 : 1 Triax (75 Ohm)
Insulator
T: PTFE
Rated Current
6 Amps
Specifications
Contact Type: Triaxial 75 Ohm (Solder)
Contact Dia.: 0.9 mm (0.035in)
Vtest: 1200 V (AC), 1690 V (DC)
Impedance: 75 Ohm
VSWR: 1.02 + 0.07 * f/GHz
Cable type: Belden 8215,8232A,HF-2426,Triax 8 Nokia,375 029 LEDE, RGT 179
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +200°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
L
M
S2
mm.
16
52
36
12
in.
0,63
2,05
1,42
0,47
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.2E.ZZZ.PA120
Caps:
BFA.2E.100.NAS
2/3
3/3
很抱歉,暂时无法提供与“FFA.2E.675.CTAC65”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+629.9752210+81.49692
