ERA.3T.275.CTL
ERA.3T.275.CTL
    LEMO(雷莫)
    ERA.3T.275.CTL
ERA.3T.275.CTL 数据手册
ERA.3T.275.CTL www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 3T Termination type Female solder IP rating 66 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFA.3T.275.CTAC75 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ERA*: Fixed socket, nut fixing Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 43.23 g Performance Configuration 3T.275 : 1 Coax (75 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Contact Type: Solder Vtest: (unknown)1200 V (AC), 1690 V (DC) Impedance: (unknown)75 Ohm Others Endurance (Shell): >1000 mating cycles Temp (min / max): -55°C / +200°C LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Humidity (max): 1000 hr DRAWINGS RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
ERA.3T.275.CTL
物料型号:ERA.3T.275.CTL 器件简介:LEMO公司生产的连接器,具有固定插座和螺母固定方式。 引脚分配:1个同轴电缆连接。 参数特性: - 额定电流:6安培 - 电压测试:1200伏交流或1690伏直流 - 阻抗:75欧姆 - 环境耐受性:-55°C至+200°C的工作温度范围,最大湿度95%(在60°C/140°F时) - 抗振性:15g(10Hz至2000Hz) - 抗冲击性:100g(6ms) - 气候类别:50/175/21 - 屏蔽效率:最小95dB(在10MHz时)和80dB(在1GHz时) - 盐雾耐腐蚀性:超过1000小时 功能详解:文档提供了连接器的机械结构、电气性能和环境适应性等详细信息。 应用信息:适用于需要高可靠性和环境适应性的场合。 封装信息:ERA型固定插座,采用圆形键槽,材料为镀铬黄铜壳体和螺母,镍镀黄铜拉杆套和中间件,重量为43.23克。
ERA.3T.275.CTL 价格&库存
很抱歉,暂时无法提供与“ERA.3T.275.CTL”相匹配的价格&库存,您可以联系我们找货
