ERA.3E.250.KTL
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
3E
Termination type
Female solder Coaxial
IP rating
68 when mated
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
obsolete
Matching parts
FFA.3E.250.KTAC11
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
ERA*: Fixed receptacle, nut fixing
Keying
Circular, female
Housing Material
Brass (black chrome) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch
sleeve and mid pieces
Weight
65.99 g
Performance
Configuration
3E.250 : 1 Coax (50 Ohm)
Insulator
T: PTFE
Rated Current
26 Amps
Specifications
Contact Type: Solder
Vtest: 3000 V (AC), 4200 V (DC)
Impedance: 50 Ohm
VSWR: 1.06 + 0.5 * f/GHz
Cable type: RG 213/U, RG 115 A/U, RG 11 A/U, RG 144/U, RG 165 /U
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +200°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
B
E
L
M
S1
S3
e
mm.
31
34
11
34
6
22.5
30
M24x1.0
in.
1,22
1,34
0,43
1,34
0,24
0,89
1,18
RECOMMENDED BY LEMO
Tools
2/3
3/3
很抱歉,暂时无法提供与“ERA.3E.250.KTL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+640.37225100+83.10863
