SF3321-60004
SF3321-60004
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONN1.85MMJCKSTR50OHMSOLDER
SF3321-60004 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV DATE APPROVED - REV. DCN 39276 08/09/12 STW A REV. DCN 48229 01/04/19 STW 2X .313 7.94 HEX. .921 23.38 .250±.002 6.35±0.05 ACROSS FLAT .485 12.32 .250[6.35] HEX M7 X .75-6g MATERIAL: .150 3.81 MAX. PANEL BODY, HEX NUT, FERRULE, CLAMP NUT, & INSERT: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 OR ASTM A582, TYPE 303, CONDITION A. .252 6.40 MIN. CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04. LOCKWASHER: STAINLESS STEEL 300 SERIES INSULATOR: PCTFE PER ASTM D1430 FINISH: BODY, HEX NUT, CLAMP NUT & INSERT: PASSIVATED PER AMS 2700. FERRULE & CONTACT: .277 7.04 MIN. GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .000050" MIN. RECOMMENDED MOUNTING HOLE PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: DWV: OPERATING TEMP.: ENGAGEMENT/ DISENGAGEMENT: 50 OHMS DC TO 65.0 GHz 1.33:1 DC TO 65.0 GHz .03 X SQRT(F(F IN GHz)) 500 VRMS -55 C TO +125 C 2 IN-LBS MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JMC 08/08/12 CHECKED: APPROVED: STW 08/09/12 STW 08/09/12 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: 1.85MM JACK, BULKHEAD MT. FOR .047 CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 5:1 SF3321-60004 SHEET 1 OF 1
SF3321-60004 价格&库存
很抱歉,暂时无法提供与“SF3321-60004”相匹配的价格&库存,您可以联系我们找货
SF3321-60004
  • 1+1469.889091+190.15260
