8921-60031-TD
8921-60031-TD
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMZJACKSTR50OHMEDGEMNT
8921-60031-TD 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV - DCN 42247 DATE APPROVED 05/16 DAL .200 5.08 4X .062±.001 1.57±0.03 .250 6.35 .0380±.0015 0.97±0.04 .300 7.62 5X .155 3.94 .200 5.08 .010 0.25 RECOMMENDED MOUNTING HOLE PATTERN .180 4.57 .035 0.88 MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: .030 0.76 SOLDER 4X .040±.002 1.02±0.05 PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: BODY & CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. NOTES: 1. 2. TO BE TIN DIPPED USING Sn96 SOLDER. ALL DIMENSIONS APPLY PRIOR TO SOLDER DIPPING. PERFORMANCE: MATERIAL: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: DWV: 50 OHMS DC TO 18.0 GHz 1.30:1 DC TO 18.0 GHz .03 X SQRT(F(F IN GHz)) 1000 VRMS FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: GPF 05/16/16 CHECKED: APPROVED: DAL 05/16/16 DAL 05/16/16 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMZ FEMALE PCB MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 8:1 8921-60031-TD SHEET 1 OF 1
8921-60031-TD 价格&库存
很抱歉,暂时无法提供与“8921-60031-TD”相匹配的价格&库存,您可以联系我们找货
