SF3311-60002
SF3311-60002
    AMPHENOLSVMICROWAVE(安费诺MAO)
    1.85MM MALE CONNECTOR FOR .047 C
SF3311-60002 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV B REV. DCN 48043 DATE 10/23/18 APPROVED STW .624 15.84 .312 7.92 HEX .353 8.97 MATERIAL: BODY, CLAMP NUT, COUPLING NUT & FERRULE: 2X .250[6.35] HEX STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 OR ASTM A582, TYPE 303, CONDITION A. CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04. LOCK RING: BERYLLIUM COPPER PER ASTM B194, B196 OR B197 ALLOY No. UNS C17200 OR C17300. INSULATOR: PEI (ULTEM 1000) PER ASTM D2505. GASKET: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 60/70. FINISH: CONTACTS & FERRULE: BODY, CLAMP NUT & COUPLING NUT: GOLD PER ASTM B 488, TYPE II, CODE C, CLASS 1.27 OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PASSIVATED PER AMS 2700 PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: DWV: OPERATING TEMP.: 50 OHMS DC TO 65.0 GHz 1.33:1 DC TO 65.0 GHz .03 X SQRT F(F IN GHz) 500 VRMS -55 C TO +125 C MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY ENGAGEMENT/ DISENGAGEMENT: 2 IN-LBS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JMC 10/23/18 CHECKED: APPROVED: STW 10/23/18 STW 10/23/18 www.svmicrowave.com TITLE: 1.85MM PLUG FOR Ø.047 CABLE SIZE B SCALE: 8:1 DWG. NO. SF3311-60002 SHEET 1 OF 1
SF3311-60002 价格&库存
很抱歉,暂时无法提供与“SF3311-60002”相匹配的价格&库存,您可以联系我们找货
SF3311-60002
  • 25+1412.6555025+183.10705
