FFA.4S.250.CTAC10
FFA.4S.250.CTAC10
    LEMO(雷莫)
    CONN INLINE PLUG COAX PIN SLDER
FFA.4S.250.CTAC10 数据手册
FFA.4S.250.CTAC10 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 4S Termination type Male solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 9.10 - 10.00 mm Status active Matching parts ERA.4S.250.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 144.27 g Performance Configuration 4S.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 36 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 4 mm (0.157in) Bucket Dia.: 3.7 mm (0.146in) Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 1.9 * f/GHz Cable type: RG 214 /U, RG 216 /U, RG 225 /U, RG 225 /U, RG 213/U, RG 115 A/U, RG 11 A/U, RG 144/U, RG 165 /U LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 24.8 77 59 19 in. 0,98 3,03 2,32 0,75 RECOMMENDED BY LEMO Tools Caps: BFA.4S.100.NAS LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.4S.250.CTAC10 价格&库存
很抱歉,暂时无法提供与“FFA.4S.250.CTAC10”相匹配的价格&库存,您可以联系我们找货
