SF8802-6007
SF8802-6007
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBZPLUGSTR50OHMSOLDER
SF8802-6007 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING A DCN 42825 DATE APPROVED 11/16 STW .782 19.86 .450 11.43 .624 15.85 .180±.002 4.57±0.05 .300 7.62 MATERIAL: BODY & FERRULE: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1; OR ASTM A582 TYPE 303, COND. A .050 MIN 1.27 MIN LOCK RING, CONTACT, OUTER CONTACT & RETAINING RING: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B GASKET: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 60/70 COMPRESSION SPRING: STAINLESS STEEL 17-7PH .018±.003 X 45° .406±.001 10.31±0.03 .430±.002 10.92±0.05 FINISH: BODY: FERRULE, CONTACT, & OUTER CONTACT: RETAINING CLIP & LOCK RING: PASSIVATED PER AMS-2700 .052±.003 1.32±0.08 GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.52, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. NICKEL PER AMS-QQ-N-290, CLASS 1, GRADE G RECOMMENDED MOUNTING HOLE MATERIAL: FINISH: PERFORMANCE: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 6.0 GHz. THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: GPF 11/9/16 CHECKED: APPROVED: STW 11/9/16 STW 11/9/16 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BZ BLIND MATE PLUG FOR .141 S.R. CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 SF8802-6007 SHEET 1 OF 1
SF8802-6007 价格&库存
很抱歉,暂时无法提供与“SF8802-6007”相匹配的价格&库存,您可以联系我们找货
SF8802-6007
  • 25+2151.3335225+279.03487
