FFA.4S.675.CTAC10Z
www.lemo.com
SUMMARY
# Wires
Triax
1
Image is for illustrative purpose only
Series
4S
Termination type
Male solder
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
9.10 - 10.00 mm
Status
active
Matching parts
ERA.4S.675.CTL
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FFA*: Straight plug, cable collet and nut for fitting a bend relief
Keying
Circular, male
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Variant
Z : Nut for fitting a bend relief
Weight
152.76 g
Performance
Configuration
4S.675 : 1 Triax (75 Ohm)
Insulator
T: PTFE
Rated Current
15 Amps
Specifications
Contact Type: Solder
Vtest: 1500 V (AC), 2100 V (DC)
Impedance: 75 Ohm
VSWR: 1.01 + 0.14 * f/GHz
Cable type: Belden 8215,8232A,HF-2426,Triax 8 Nokia,375 029 LEDE, Belden 9267,8233A, Triax 11 Nokia,466 140
LEDE
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
DRAWINGS
Dimensions
A
L
M
S2
mm.
24.8
77
59
in.
0,98
3,03
2,32
0,79
RECOMMENDED BY LEMO
Tools
Caps:
BFA.4S.100.NAS
2/3
3/3
很抱歉,暂时无法提供与“FFA.4S.675.CTAC10Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+1225.7436125+158.87971
