3211-60181
3211-60181
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPMPLUGR/A50OHMEDGEMNT
3211-60181 数据手册
8 7 6 4 5 ROHS COMPLIANT 1 2 3 REVISION HISTORY PRODUCT DATA DRAWING REV. - DATE DESCRIPTION APPROVED 05/16 NRN 40631 STW F F 2.280 2X .052 ALIGNMENT PINS .107±.001 RP .201 .114 .340 E A .233 8X .039 2X .069±.002 .119 0-80 UNF-2B THRU 2X 1-64 UNC-2B THRU 8X .059±.002 E DETAIL A SCALE 7 : 1 .012±.001 .115 1.140 7X .250 .220 .059 D D 2.420 .205 .008 .394 2X .070 DETAIL B SCALE 7 : 1 C B 8X .051 8X .051 C 6X .020 2X .052 ALIGNMENT PINS .220 .070±.002 .150±.001 1.980 .060±.002 MATERIAL: B BODY & SHROUDS: B STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1; OR ASTM A582 TYPE 303, COND. A CONTACTS: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATORS: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com FINISH: MATERIAL: BODY, SHROUDS, & CONTACTS: A FINISH: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 0.76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00010" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: 8 50 OHMS DC TO 65 GHz. SEE NOTES SEE NOTES DIMENSIONS ARE IN INCHES TOLERANCES: ANGULAR: 1 ONE PLACE DECIMAL .030 TWO PLACE DECIMAL .010 THREE PLACE DECIMAL .005 DO NOT SCALE DRAWING INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 PROPRIETARY THIRD ANGLE PROJECTION 7 6 5 ALL DIMENSIONS ARE AFTER PLATING. BREAK CORNERS & EDGES R.005 MAX. CHAMFER 1ST AND LAST THREAD. SURFACE ROUGHNESS 63 PER MIL-STD-10. DIA'S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 6. REMOVE ALL BURRS. DRAWN: CHECKED: THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC. IS PROHIBITED. APPROVED: E.M. SIMULATION: 4 SV Microwave, Inc.® UNLESS OTHERWISE SPECIFIED: 1. 2. 3. 4. 5. 3 FED 05/27/16 STW 05/27/16 STW 05/27/16 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPM FD MALE 8-PORT EDGE LAUNCH SIZE CAGE CODE C 95077 SCALE: 4:1 2 DWG. NO. 3211-60181 SHEET 1 OF 2 1 A 8 7 6 4 5 ROHS COMPLIANT 1 2 3 REVISION HISTORY PRODUCT DATA DRAWING REV. DESCRIPTION DATE APPROVED SEE SHEET 1 F F 2.100 2X 1.980 4X .074 THRU .052 2X .138 2X .138 E E 2.260 .080 D D (2X .121) PIN EXTRUSION C C B B MATERIAL: FINISH: SEE NOTES SEE NOTES A DIMENSIONS ARE IN INCHES TOLERANCES: ANGULAR: 1 .030 ONE PLACE DECIMAL TWO PLACE DECIMAL .010 THREE PLACE DECIMAL .005 DO NOT SCALE DRAWING INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 PROPRIETARY THIRD ANGLE PROJECTION 8 7 6 5 ALL DIMENSIONS ARE AFTER PLATING. BREAK CORNERS & EDGES R.005 MAX. CHAMFER 1ST AND LAST THREAD. SURFACE ROUGHNESS 63 PER MIL-STD-10. DIA'S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 6. REMOVE ALL BURRS. DRAWN: CHECKED: THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC. IS PROHIBITED. APPROVED: E.M. SIMULATION: 4 SV Microwave, Inc.® UNLESS OTHERWISE SPECIFIED: 1. 2. 3. 4. 5. 3 FED 05/27/16 STW 05/27/16 STW 05/27/16 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPM FD MALE 8-PORT EDGE LAUNCH SIZE CAGE CODE C 95077 SCALE: 4:1 2 DWG. NO. 3211-60181 SHEET 2 OF 2 1 A
3211-60181 价格&库存
很抱歉,暂时无法提供与“3211-60181”相匹配的价格&库存,您可以联系我们找货
