SF8901-6003
SF8901-6003
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMZPLUGSTR50OHMSOLDER
SF8901-6003 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING A DNC 33622 DATE APPROVED 09/05 VMJ .569±.004 14.45±0.10 .390 9.91 .740 18.80 .146±.001 3.71±0.03 .260 6.60 .593 15.06 MATERIAL: BODY, FLANGE: LOCK RING & CONTACTS: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 .382±.002 9.70±0.05 BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 REAR BODY: BRASS PER ASTM B16, ALLOY UNS No. C36000 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B GASKET: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 50/60 SPRING: STAINLESS STEEL PER ASTM A302 .145 3.68 2X 2-56 UNC-2B .090 2.29 +0.13 +.005 9.78 .385 0 - .000 FINISH: .593 15.06 BODY, FLANGE, SPRING: REAR BODY, CONTACTS: LOCK RING: .297 7.53 PASSIVATED PER AMS-2700, TYPE 2 GOLD PER ASTM B488, TYPE II, CODE C, CLASS 0.76; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. 2X .102±.002 2.59±0.05 RECOMMENDED MOUNTING HOLE SCALE 3:1 NICKEL PER AMS-QQ-N-290, CLASS 1, GRADE G MATERIAL: PERFORMANCE: FINISH: IMPEDANCE: FREQ. RANGE: DWV: FORCE TO ENGAGE: FORCE TO DISENGAGE: 50 OHMS 2.0 TO 18.0 GHz 1000 VRMS 12 OUNCES MAX 2 OUNCES MIN SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: BRT 09/21/05 CHECKED: APPROVED: STW 02/09/00 STW 02/09/00 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMZ STRAIGHT PLUG FOR .141 SEMI-RIGID CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 SF8901-6003 SHEET 1 OF 1
SF8901-6003 价格&库存
很抱歉,暂时无法提供与“SF8901-6003”相匹配的价格&库存,您可以联系我们找货
