PHG.4M.650.CTAC90
PHG.4M.650.CTAC90
    LEMO(雷莫)
    CONNTRIAXRCPTSTR50OHMSOLDER
PHG.4M.650.CTAC90 数据手册
PHG.4M.650.CTAC90 www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 4M Termination type Male solder IP rating 66 AWG wire size 0.00 - 0.00 Cable Ø 8.60 - 9.00 mm Status active Matching parts FGG.4M.650.CTLC90 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PHG*: Straight receptacle with cable collet Keying 1 key (alpha=0; plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 167.03 g Performance Configuration 4M.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 26 Amps Specifications Contact Type: Triaxial 50 Ohm (Solder) Vtest: 1800 V (AC), 2540 V (DC) Impedance: 50 Ohm Others Humidity (max): 1000 hr DRAWINGS Dimensions A B L S2 mm. 29 25 75.5 19 in. 1,14 0,98 2,97 0,75 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
PHG.4M.650.CTAC90 价格&库存
很抱歉,暂时无法提供与“PHG.4M.650.CTAC90”相匹配的价格&库存,您可以联系我们找货
