FFA.3T.675.CTAY92S
FFA.3T.675.CTAY92S
    LEMO(雷莫)
    FFA.3T.675.CTAY92S
FFA.3T.675.CTAY92S 数据手册
FFA.3T.675.CTAY92S www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 3T Termination type Male solder IP rating 66 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts PCA.3T.675.CTLY92 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug with cable clamping Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 80.40 g Performance Configuration 3T.675 : 1 Triax (75 Ohm) Insulator T: PTFE Rated Current 8 Amps Specifications Contact Type: Triaxial 75 Ohm (Solder) Vtest: 1200 V (AC), 1690 V (DC) Impedance: 75 Ohm Others Endurance (Shell): >1000 mating cycles Temp (min / max): -55°C / +200°C LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Humidity (max): 1000 hr DRAWINGS Dimensions B L S1 mm. 20 71 18 in. 0,79 2,80 0,71 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
FFA.3T.675.CTAY92S 价格&库存
很抱歉,暂时无法提供与“FFA.3T.675.CTAY92S”相匹配的价格&库存,您可以联系我们找货
