FLA.3E.275.CLAC11E
FLA.3E.275.CLAC11E
    LEMO(雷莫)
    CONNCOAXPLUGR/A75OHMSOLDER
FLA.3E.275.CLAC11E 数据手册
FLA.3E.275.CLAC11E www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 3E Termination type Male solder Coaxial IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 10.10 - 10.50 mm Status active Matching parts ERA.3E.275.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FLA*: Elbow plug, cable collet Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant E : Gasket and O-ring in EPDM Weight 99.41 g Performance Configuration 3E.275 : 1 Coax (75 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 15 Amps Specifications Contact Type: Solder Vtest: 2700 V (AC), 3900 V (DC) Impedance: 75 Ohm VSWR: 1.04 + 0.05 * f/GHz Cable type: RG 213/U, RG 115 A/U, RG 11 A/U, RG 144/U, RG 165 /U LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A D H L M S1 S2 S3 mm. 21 11.5 47 60 40 18 15 16 in. 0,83 0,45 1,85 2,36 1,57 0,71 0,59 0,63 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FLA.3E.275.CLAC11E 价格&库存
很抱歉,暂时无法提供与“FLA.3E.275.CLAC11E”相匹配的价格&库存,您可以联系我们找货
