HGP.3E.275.CLLPE
HGP.3E.275.CLLPE
    LEMO(雷莫)
    CONNCOAXRCPTSTR75OHMSOLDER
HGP.3E.275.CLLPE 数据手册
HGP.3E.275.CLLPE www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 3E Termination type Female solder Coaxial IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model HGP*: Fixed receptacle, nut fixing, watertight or vacuum-tight Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant P : Watertight unmated Weight 74.39 g Performance Configuration 3E.275 : 1 Coax (75 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 15 Amps Specifications Contact Type: Solder Vtest: 2700 V (AC), 3900 V (DC) Impedance: 75 Ohm VSWR: 1.04 + 0.05 * f/GHz Cable type: RG 213/U, RG 115 A/U, RG 11 A/U, RG 144/U, RG 165 /U LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -20°C / +80°C Humidity (max): 1000 hr Pressure: 30 bars DRAWINGS Dimensions A B E L M S1 S3 e mm. 31 34 15.5 39.5 6 22.5 30 M24x1.0 in. 1,22 1,34 0,61 1,56 0,24 0,89 1,18 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
HGP.3E.275.CLLPE 价格&库存
很抱歉,暂时无法提供与“HGP.3E.275.CLLPE”相匹配的价格&库存,您可以联系我们找货
