PCA.5S.250.CLLC11
PCA.5S.250.CLLC11
    LEMO(雷莫)
    CONNCOAXRCPTSTR50OHMSOLDER
PCA.5S.250.CLLC11 数据手册
PCA.5S.250.CLLC11 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 5S Termination type Female solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 10.10 - 11.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PCA*: Free receptacle, cable collet Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 374.26 g Performance Configuration 5S.250 : 1 Coax (50 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 45 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 5 mm (0.197in) Vtest: 3000 V (AC), 4200 V (DC) Impedance: 50 Ohm VSWR: 1.02 + 2.3 * f/GHz Cable type: RG 214 /U, RG 216 /U, RG 225 /U Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L S2 mm. 34.7 99 29 in. 1,37 3,90 1,14 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PCA.5S.250.CLLC11 价格&库存
很抱歉,暂时无法提供与“PCA.5S.250.CLLC11”相匹配的价格&库存,您可以联系我们找货
