ERA.1E.275.SLL
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
1E
Termination type
Female solder Coaxial
IP rating
68 when mated
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
active
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
ERA*: Fixed receptacle, nut fixing
Keying
Circular, female
Housing Material
Stainless steel shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and
mid pieces
Weight
17.69 g
Performance
Configuration
1E.275 : 1 Coax (75 Ohm)
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
10 Amps
Specifications
Contact Type: Solder
Vtest: 2400 V (AC), 3300 V (DC)
Impedance: 75 Ohm
VSWR: 1.02 + 0.08 * f/GHz
Cable type: RG 179 B/U, RG 187 A/U, RG 58 C/U, RG 302 /U, RG 400 /U, 2YCCY, RG 59 B/U, RG 223 /U, HF-5408
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +200°C
Humidity (max):
很抱歉,暂时无法提供与“ERA.1E.275.SLL”相匹配的价格&库存,您可以联系我们找货
