FFA.5S.250.CLAC16
FFA.5S.250.CLAC16
    LEMO(雷莫)
    CONNCOAXPLUGSTR50OHMSOLDER
FFA.5S.250.CLAC16 数据手册
FFA.5S.250.CLAC16 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 5S Termination type Male solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 15.10 - 16.00 mm Status active Matching parts ERA.5S.250.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 341.30 g Performance Configuration 5S.250 : 1 Coax (50 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 45 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 5 mm (0.197in) Vtest: 3000 V (AC), 4200 V (DC) Impedance: 50 Ohm VSWR: 1.02 + 2.3 * f/GHz Cable type: RG 214 /U, RG 216 /U, RG 225 /U Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 35 103 78 29 in. 1,38 4,06 3,07 1,14 RECOMMENDED BY LEMO Tools Caps: BFA.5S.100.NAS LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.5S.250.CLAC16 价格&库存
很抱歉,暂时无法提供与“FFA.5S.250.CLAC16”相匹配的价格&库存,您可以联系我们找货
