FZP.1E.275.SLAC65
FZP.1E.275.SLAC65
    LEMO(雷莫)
    CONNCOAXPLUGSTR75OHMSOLDER
FZP.1E.275.SLAC65 数据手册
FZP.1E.275.SLAC65 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 1E Termination type Male solder Coaxial IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 6.10 - 6.50 mm Status active Matching parts ERA.1E.275.SLL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FZP*: Straight plug for remote handling, cable collet and inner anti-rotating device Keying Circular, male Housing Material Stainless steel shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 39.61 g Performance Configuration 1E.275 : 1 Coax (75 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Vtest: 2400 V (AC), 3300 V (DC) Impedance: 75 Ohm VSWR: 1.02 + 0.08 * f/GHz Cable type: RG 179 B/U, RG 187 A/U, RG 58 C/U, RG 302 /U, RG 400 /U, 2YCCY, RG 59 B/U, RG 223 /U, HF-5408 Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max):
FZP.1E.275.SLAC65 价格&库存
很抱歉,暂时无法提供与“FZP.1E.275.SLAC65”相匹配的价格&库存,您可以联系我们找货
