FGG.4M.650.CTLC90
FGG.4M.650.CTLC90
    LEMO(雷莫)
    CONNTRIAXPLUGSTR50OHMSOLDER
FGG.4M.650.CTLC90 数据手册
FGG.4M.650.CTLC90 www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 4M Termination type Female solder IP rating 66 AWG wire size 0.00 - 0.00 Cable Ø 8.60 - 9.00 mm Status active Matching parts ENG.4M.650.CTA Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FGG*: Straight plug with cable collet Keying 1 key (alpha=0; plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 150.31 g Performance Configuration 4M.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 26 Amps Specifications Contact Type: Triaxial 50 Ohm (Solder) Vtest: 1800 V (AC), 2540 V (DC) Impedance: 50 Ohm Others Humidity (max): 1000 hr DRAWINGS Dimensions A L M S2 mm. 25 73 53 19 in. 0,98 2,87 2,09 0,75 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
FGG.4M.650.CTLC90 价格&库存
很抱歉,暂时无法提供与“FGG.4M.650.CTLC90”相匹配的价格&库存,您可以联系我们找货
