CP-88-6
CP-88-6
    CINCH
    CONN BNC PLUG STR 50 OHM PUSH
CP-88-6 数据手册
50 Ohm BNC Straight Crimp Type Plug Push-On Body - 2 Piece PART NUMBER CP-88-6 CABLE TYPE TIMES FIBER 2240 CABLE CENTER CONDUCTOR “A” “B” SOLID .843 (21.41) .540 (13.72) INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST WIRE WIRE JACKET GAUGE DECIMAL O.D. 22-18 .025 (.064)-.043 (1.09) .262 (6.65)-.275 (6.99) 1. Identify connector parts. (2 piece parts) 2. Slide crimp sleeve over cable and strip cable jacket to dimension shown. Do not nick braid or center conductor during strip operations. 3. Flair braid and fold back. Strip cable insulation to dimension shown. Do not nick center conductor. 4. Insert center conductor into the guide hole found in the rear of the connector body. Push or twist the body onto the center conductor until the cable insulation butts up to the body. 5. Arrange braid uniformly around crimp stem. Slide crimp sleeve over braid and crimp securely using recommended crimp tool. Part Number CP-88-6 Cable TIMES MI2040 Crimp (Braid Hex) .340 (8.64) Crimp (Strain (Relief) .264 (6.71) Recommended Crimp Tool 24-303P Cambridge Products, P.O. Box 1732, Waseca, MN 56093-0832 • 1-800-243.8814 • Fax: 507-833-6287 • www.cambridgeproducts.com BNC Connectors Specifications INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST The BNC series connector is a commercial quality product that intermates with all standard double bayonet stud BNC designs. All contacts are captivated for ruggedness. The 50 ohm and 75 ohm interfaces are intermateable and provide quick, reliable connections for instrumentation, medical and LAN applications. Specifications* 50 Ohm BNC Electrical Characteristics Impedance: 50 Ohm nominal Frequency range: 0-4 GHz Working voltage: 500 volts RMS at sea level Dielectric withstanding voltage: 1500 volts RMS at sea level Corona level: 375 volts minimum at 70,000 feet Contact resistance: Outer - 0.2 milliohms maximum Center - 2.1 milliohms maximum Insulation resistance: 5000 megohms minimum Environmental Characteristics Recommended temperature range: -55OC to +85OC Moisture resistance: MIL-STD-202 Mechanical Characteristics Durability: 500 cycles Force to engage/disengage: 3 lbs. maximum Cable retention: 20 lbs., RG-58 C/U cable Materials Body: Zinc or brass Contact: Brass, beryllium copper or phosphor bronze Spring Washer: Beryllium copper Crimp sleeve: Brass Insulator: Delrin® or TPX Polymethylpentene Plating: Body - Nickel (except where noted) Crimp sleeve - Nickel Contact - Gold * These values are typical and may not apply to all connectors. Cambridge Products, P.O. Box 1732, Waseca, MN 56093-0832 • 1-800-243.8814 • Fax: 507-833-6287 • www.cambridgeproducts.com
CP-88-6 价格&库存
很抱歉,暂时无法提供与“CP-88-6”相匹配的价格&库存,您可以联系我们找货
