CONREVMCX011
CONREVMCX011
    LINXTECHNOLOGIES(灵思)
    CONN RP-MCX JACK 50 OHM SOLDER
CONREVMCX011 数据手册
Description Body Pin Insulation Crimp Ring Heat Shrink Material Brass PH Bronze PTFE Brass Polyolefin Finish Gold Gold N/A Gold Black REVISIONS HEAT SHRINK REV DESCRIPTION DATE APPV B Added new title block and heat shrink; updated instructions 11-JUL-12 SAH Ø0.197 (5.00) 0.787 (20.00) SIDE VIEW CRIMP RING PIN Ø0.197 (5.00) Ø0.102 (2.60) Ø0.154 (3.90) Ø0.037 (0.95) 0.232 (5.90) 0.276 (7.00) 0.382 (9.70) 0.575 (14.60) CONREVMCX011 ASSEMBLY INSTRUCTIONS 1. 2. 3. 4. 5. 6. NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. RECOMMENDED CABLE STRIPPING DIMENSIONS 0.079 (2.00) 0.102 (2.60) 0.189 (4.80) RG-174 Cable Strip the cable to the recommended dimensions. Slip heat shrink and crimp ring onto stripped cable. Solder the pin to the center conductor. Insert the pin, center conductor, and insulator into the body until the pin snaps in. Wrap the braid around the tail of the body and crimp the ring with a 0.128" hex crimp tool (or one labeled for use with RG-174 cable). Use heat shrink to cover crimp. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 159 ORT LANE MERLIN, OR 97532 TITLE: RP-MCX FEMALE CABLE END CRIMP FOR RG174 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 11-JUL-12 ENGR: S.HOGAN DT: 11-JUL-12 SCALE: 2:1 REV CONREVMCX011 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONREVMCX011 价格&库存
很抱歉,暂时无法提供与“CONREVMCX011”相匹配的价格&库存,您可以联系我们找货
