CONREVMCX011-R178
CONREVMCX011-R178
    LINXTECHNOLOGIES(灵思)
    CONN RP-MCX JACK 50 OHM SOLDER
CONREVMCX011-R178 数据手册
Description Body Pin Insulation Spacer Support Heat Shrink Material Brass PH Bronze PTFE PTFE Brass Polyolefin Finish Gold Gold N/A N/A Gold Black REVISIONS HEAT SHRINK REV DESCRIPTION DATE APPV B Added new title block and heat shrink; updated instructions 11-JUL-12 SAH Ø0.118 (3.00) 0.787 (20.00) SIDE VIEW PIN Ø0.197 (5.00) Ø0.106 (2.70) 0.232 (5.90) SPACER SUPPORT Ø0.037 (0.95) 0.382 (9.70) 0.575 (14.60) CONREVMCX011-R178 ASSEMBLY INSTRUCTIONS 1. 2. 3. 4. 5. 6. 7. 8. Strip the cable to the recommended dimensions. Slip heat shrink onto stripped cable. Solder the support onto the braid. Place the spacer onto the center conductor. Solder or crimp the pin onto the center conductor. Insert the pin, center conductor, spacer, and support into the body until the pin snaps in. Crimp the tail of the body onto the support with a 0.093” hex crimp tool (or one labeled for use with RG-178 cable). Use heat shrink to cover crimp. RECOMMENDED CABLE STRIPPING DIMENSIONS 0.079 0.071 (2.00) (1.80) 0.197 (5.00) RG-178 Cable NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: 159 ORT LANE MERLIN, OR 97532 RP-MCX FEMALE CABLE END CRIMP FOR RG178 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 11-JUL-12 ENGR: S.HOGAN DT: 11-JUL-12 SCALE: 2:1 REV CONREVMCX011-R178 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONREVMCX011-R178 价格&库存
很抱歉,暂时无法提供与“CONREVMCX011-R178”相匹配的价格&库存,您可以联系我们找货
