131-1693-101
131-1693-101
    CINCH
    CONN SMB PLUG R/A 50 OHM SOLDER
131-1693-101 数据手册
SMB/SMC Solder Type Right Angle Plugs for Semi-Rigid Cable 1. Identify connector parts. (2 piece parts – except diecast) 2. Strip cable to dimensions shown. Do not nick center conductor. 3. Insert cable into body making certain that the cable insulation bottoms on center contact. Solder center conductor to contact through the rear and side access ports. Use a minimum amount of solder for a good joint. .020 (0.51) diameter solder is recommended. 4. Solder body to cable. Use a minimum amount of heat to minimize cable insulation movement. Place expansion cap in access port and set with .125 (3.17) diameter punch. Snap cover ring over side access port. Cable Group RG-405/U (.086 Semi-Rigid) 254 Part No. 131-1693-101 131-1693-116 131-3693-101 131-3693-116 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
131-1693-101 价格&库存
很抱歉,暂时无法提供与“131-1693-101”相匹配的价格&库存,您可以联系我们找货
  • 25+77.1671725+10.01238
