CONREVMCX002-L
CONREVMCX002-L
    LINXTECHNOLOGIES(灵思)
    CONN RP-MCX JACK R/A 50 OHM PCB
CONREVMCX002-L 数据手册
Description Body Pin Insulation Washer Nut Material Brass PH Bronze PTFE Brass Brass Finish Gold Gold N/A Gold Gold REVISIONS REV B SIDE VIEW FLAT 0.173 (4.40) 0.535 (13.60) 0.370 (9.40) Updated footprint and dimensions; Added new title block BACK VIEW S0.236 (6.00) 0.217 (5.50) DESCRIPTION 10-56UNS-2A THREADS NUT APPV 11-JUL-12 SAH RECOMMENDED MOUNTING HOLE 0.110 (2.8) FLAT 0.173 (4.40) 0.035 (0.90) 0.154 (3.90) DATE 0.165 (4.20) WASHER 0.035 (0.90) Ø0.187 (4.75) S0.236 (6.00) Ø0.037 (0.95) H0.250 (6.35) 10-56UNS-2B THREADS Ø0.377 (9.57) RECOMMENDED FOOTPRINT 0.100 (2.54) 0.200 (5.08) 0.100 (2.54) 0.055 (1.40) Ø0.040 (1.02) 0.020 (0.50) : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: 4-Ø0.051 (1.30) NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: 159 ORT LANE MERLIN, OR 97532 RP-MCX FEMALE RIGHT ANGLE PCB MOUNT - EXTENDED SIZE DWG. NO. REV CONREVMCX002-L B DRAWN: B.MURPHY DT: 11-JUL-12 ENGR: S.HOGAN DT: 11-JUL-12 SCALE: 2:1 DO NOT SCALE DRAWING SHEET 1 OF 1 LDCFDLT_A
CONREVMCX002-L 价格&库存
很抱歉,暂时无法提供与“CONREVMCX002-L”相匹配的价格&库存,您可以联系我们找货
