CONREVMCX005-R178
CONREVMCX005-R178
    LINXTECHNOLOGIES(灵思)
    CONN RP-MCX JACK 50 OHM SOLDER
CONREVMCX005-R178 数据手册
Description Body Pin Insulation Nut Washer Heat Shrink Support Spacer Material Brass PH Bronze PTFE Brass Brass Polyolefin Brass PTFE Finish Gold Gold N/A Gold Gold Black Gold N/A REVISIONS RECOMMENDED MOUNTING HOLE REV B DESCRIPTION DATE Added new title block and heat shrink; Updated instructions 11-JUL-12 SAH HEAT SHRINK FLAT 0.173 (4.40) Ø0.118 (3.00) SIDE VIEW 10-56 UNS-2A THREADS APPV Ø0.187 (4.75) H0.250 (6.35) FLAT 0.173 (4.40) 0.787 (20.00) PIN Ø0.106 (2.70) SPACER SUPPORT Ø0.037 (0.95) 0.232 (5.90) CONREVMCX005-R178 ASSEMBLY INSTRUCTIONS 0.272 (6.90) 0.378 (9.60) NUT WASHER 0.571 (14.50) H0.250 (6.35) 7. Ø0.377 (9.57) 8. 9. 10-56 UNS-2B THREADS 0.055 (1.40) RECOMMENDED CABLE STRIPPING DIMENSIONS 0.138 0.024 (3.50) (0.60) 0.197 (5.00) RG-178 Cable 1. 2. 3. 4. 5. 6. 0.020 (0.50) Strip the cable to the recommended dimensions. Slip heat shrink onto the stripped cable. Solder the support onto the braid. Place the spacer onto the center conductor. Solder or crimp the pin onto the center conductor. Insert the pin, center conductor, spacer, and support into the body until the pin snaps in. Crimp the tail of the body onto the support with a 0.093” hex crimp tool (or one labeled for use with RG-178 cable). Use heat shrink to cover crimp. Use the nut and washer to secure the connector to a case. NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 159 ORT LANE MERLIN, OR 97532 TITLE: RP-MCX FEMALE BULKHEAD MOUNT CABLE END CRIMP FOR RG178 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 11-JUL-12 ENGR: S.HOGAN DT: 11-JUL-12 SCALE: 2:1 REV CONREVMCX005-R178 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONREVMCX005-R178
- 物料型号:RP-MCX FEMALE BULKHEAD MOUNT CABLE END CRIMP FOR RG178 CABLE - 器件简介:文档描述了一种用于RG178电缆的MCX母头压接式电缆端子的组装说明。 - 引脚分配:文档中没有明确提到引脚分配,但提到了中心导体和编织层。 - 参数特性:文档提供了材料、尺寸和公差信息,例如: - 体:黄铜,镀金 - 引脚:铍青铜,镀金 - 绝缘:PTFE,无镀层 - 螺母:黄铜,镀金 - 垫圈:黄铜,镀金 - 热缩套管:聚烯烃,黑色 - 支撑:黄铜,镀金 - 间隔器:PTFE,无镀层 - 功能详解:文档提供了组装步骤,包括剥线、焊接支撑、放置间隔器、焊接或压接引脚、组装组件、压接尾部和使用螺母和垫圈固定连接器。 - 应用信息:适用于RG178电缆的MCX母头压接式电缆端子。 - 封装信息:文档提供了详细的尺寸和公差,但没有提供封装类型的具体信息。
CONREVMCX005-R178 价格&库存
很抱歉,暂时无法提供与“CONREVMCX005-R178”相匹配的价格&库存,您可以联系我们找货
