CONN005
CONN005
    LINXTECHNOLOGIES(灵思)
    CONN N JACK STR 50 OHM SOLDER
CONN005 数据手册
Description Body Socket Insulation Crimp Ring O Ring Washer Nut NUT Material Brass Brass PTFE Brass SI Rubber Brass Brass Finish Nickel Gold N/A Nickel Rubber Nickel Nickel WASHER REVISIONS REV B DESCRIPTION Added New Title Block H0.504 (12.80) 0.531 (13.50) Ø0.866 (22.00) 0.102 (2.60) 0.929 (23.60) FLAT 0.528 x2 (13.40) 0.571 (14.50) RECOMMENDED CABLE STRIPPING DIMENSIONS 0.177 (4.50) RG-174 Cable CONN005 ASSEMBLY INSTRUCTIONS Ø0.154 (3.90) 1.421 (36.10) BASE INSULATOR 0.217 (5.50) CRIMP RING 0.374 (9.50) TOP 0.335 (8.50) SAH Ø0.634 (16.10) 0.862 (21.90) 0.276 (7.00) 0.110 (2.80) 12-JUL-12 SIDE VIEW H19 0.020 (0.50) APPV RECOMMENDED MOUNTING HOLE 5/8-24UNEF-2A THREADS 5/8-24UNEF-2B THREADS DATE 0.371 (9.50) CABLE SOCKET Solder NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. 1. Insert the cable center conductor and insulation into the base MATERIAL: 2. Solder the socket to the center conductor. 3. Wrap the braid around the tail of the body and crimp the ring with a hex crimp tool. 4. Put the socket through the insulator. FINISH: 5. Screw the base into the top. PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: MERLIN, OR 97532 N FEMALE BULKHEAD MOUNT CABLE END CRIMP FOR RG174 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 12-JUL-12 ENGR: S.HOGAN DT: 12-JUL-12 SCALE: 2:1 REV CONN005 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONN005 价格&库存
很抱歉,暂时无法提供与“CONN005”相匹配的价格&库存,您可以联系我们找货
