CONN007-R58
CONN007-R58
    LINXTECHNOLOGIES(灵思)
    CONN N PLUG STR 50 OHM SOLDER
CONN007-R58 数据手册
Description Body Pin Insulation Crimp Ring Material Brass Brass PTFE Brass Finish Nickel Gold N/A Nickel REVISIONS REV B DESCRIPTION Added New Title Block DATE APPV 12-JUL-12 SAH SIDE VIEW 5/8-24UNEF-2B THREADS 0.803 (20.40) CRIMP RING PIN 0.083 (2.10) 0.177 (4.50) Ø0.256 (6.50) 0.689 (17.50) 0.500 (12.70) 0.287 (7.30) 0.661 (16.80) 1.106 (28.10) RECOMMENDED CABLE STRIPPING DIMENSIONS 0.118 (3.00) 0.094 (2.40) 0.276 (7.00) RG-58 Cable NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE CONN007-R58 ASSEMBLY INSTRUCTIONS THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. 1. Solder the socket to the center conductor. MATERIAL: 2. Insert the socket, center conductor, and insulator into the body. 3. Wrap the braid around the tail of the body and crimp the ring with a hex crimp tool labeled for use with RG-58 cable. FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 MERLIN, OR 97532 TITLE: N MALE CABLE END CRIMP FOR RG58 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 12-JUL-12 ENGR: S.HOGAN DT: 12-JUL-12 SCALE: 2:1 REV CONN007-R58 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONN007-R58 价格&库存
很抱歉,暂时无法提供与“CONN007-R58”相匹配的价格&库存,您可以联系我们找货
