CONN011
CONN011
    LINXTECHNOLOGIES(灵思)
    CONN N JACK STR 50 OHM SOLDER
CONN011 数据手册
Description Body Socket Insulation Crimp Ring Material Brass Brass PTFE Brass Finish Nickel Gold N/A Nickel REVISIONS REV B DESCRIPTION Added New Title Block DATE APPV 12-JUL-12 SAH SIDE VIEW FLAT 0.512 x2 (13.00) 5/8-24UNEF-2A THREADS 0.630 (16.00) H0.504 (12.80) 0.102 (2.60) CRIMP RING Ø0.154 (3.90) 0.371 (9.50) 0.276 (7.00) 0.315 (8.00) 1.094 (27.80) TOP 1.421 (36.10) BASE INSULATOR CABLE SOCKET RECOMMENDED CABLE STRIPPING DIMENSIONS 0.315 (8.00) 0.098 (2.50) 0.276 (7.00) CONN011 ASSEMBLY INSTRUCTIONS RG-174 Cable Solder NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. 1. Insert the cable center conductor and insulation into the base MATERIAL: 2. Solder the socket to the center conductor. 3. Wrap the braid around the tail of the body and crimp the ring with a hex crimp tool. FINISH: 4. Put the socket through the insulator. 5. Screw the base into the top. PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 MERLIN, OR 97532 TITLE: N FEMALE CABLE END CRIMP FOR RG174 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 12-JUL-12 ENGR: S.HOGAN DT: 12-JUL-12 SCALE: 2:1 REV CONN011 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONN011 价格&库存
很抱歉,暂时无法提供与“CONN011”相匹配的价格&库存,您可以联系我们找货
