CONN012
CONN012
    LINXTECHNOLOGIES(灵思)
    CONN N PLUG R/A 50 OHM SOLDER
CONN012 数据手册
Description Body Pin Insulation Crimp Ring Cover Material Brass Brass PTFE Brass Brass Finish Nickel Gold N/A Nickel Nickel REVISIONS REV B DESCRIPTION Added New Title Block DATE APPV 12-JUL-12 SAH SIDE VIEW 1.220 (31.00) COVER CRIMP RING Ø0.500 (12.70) Ø0.154 (3.90) 0.276 (7.00) 0.787 (20.00) 0.157 (4.00) 0.079 (2.00) 0.213 (5.40) 0.197 (5.00) 5/8-24UNEF-2B THREADS Ø0.106 (2.70) RECOMMENDED CABLE STRIPPING DIMENSIONS 0.118 (3.00) 0.295 (7.50) 0.197 (5.00) NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE RG-174 Cable THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: MERLIN, OR 97532 N MALE RIGHT ANGLE CABLE END CRIMP FOR RG174 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 12-JUL-12 ENGR: S.HOGAN DT: 12-JUL-12 SCALE: 2:1 REV CONN012 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONN012 价格&库存
很抱歉,暂时无法提供与“CONN012”相匹配的价格&库存,您可以联系我们找货
