CONN012-R58
CONN012-R58
    LINXTECHNOLOGIES(灵思)
    CONN N PLUG R/A 50 OHM SOLDER
CONN012-R58 数据手册
Description Body Pin Insulation Crimp Ring Cover Material Brass Brass PTFE Brass Brass Finish Nickel Gold N/A Nickel Nickel REVISIONS REV B DESCRIPTION Added New Title Block DATE APPV 12-JUL-12 SAH SIDE VIEW 5/8-24UNEF-2B THREADS COVER 0.583 0.689 (14.80) (17.50) CRIMP RING 0.941 (23.90) Ø0.500 (12.70) Ø0.256 (6.50) 0.500 (12.70) 0.122 (3.10) 0.173 (4.40) Ø0.185 (4.70) Ø0.492 (12.50) 1.236 (31.40) NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE RECOMMENDED CABLE STRIPPING DIMENSIONS 0.118 (3.00) 0.354 (9.00) 0.295 (7.50) RG-58 Cable THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: MERLIN, OR 97532 N MALE RIGHT ANGLE CABLE END CRIMP FOR RG58 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 12-JUL-12 ENGR: S.HOGAN DT: 12-JUL-12 SCALE: 2:1 REV CONN012-R58 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONN012-R58 价格&库存
很抱歉,暂时无法提供与“CONN012-R58”相匹配的价格&库存,您可以联系我们找货
