EDSTLZ950/18
EDSTLZ950/18
    OST
    弯插,P=5.08mm
    接线端子 间距:5.08mm 1x18P 弯插
EDSTLZ950/18 数据手册
EDSTL950/X (5.0 mm) EDSTLZ950/X (5.08 mm) EDZ1710/X 2-20 poles, Spacing 3.81 mm insert required no. of poles x 2-24 poles, Spacing 5.0 mm or 5.08 mm insert required no. of poles x How to order see page 5 Ratings: Rated Voltage Rated Current Wire Size Test Voltage Rated Torque/ScrewSize 300 V 8A AWG 28-16 160 V 9 A (T60) 1.5 mm 2 4 kV/3 0.4 Nm/M2 Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 1.5 mm 2 1.0 mm 2 1.0 mm 2 Dimensions Spacing Stripped Length 3.81 mm 7.0 mm Materials Insulating Material Flammability Class Temperature Range Terminal Block Contact PA UL94 V-0 -30 C/+105 C CuZn CuSn How to order see page 5 Ratings: Rated Voltage 300 V Rated Current 15 A Rating Impulse Voltage/Dirt Level 250 V 12 A (T60) 4 kV/3 Dimensions Spacing PCB Hole Diameter 5.0 mm (5.08 mm) 1.4 mm Materials Insulating Material Flammability Class Temperature Range Contact Pin PA/PBTP UL94 V-0 -30 C/+105 C Cu Color Green Color Green 40 ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444 40
EDSTLZ950/18 价格&库存
很抱歉,暂时无法提供与“EDSTLZ950/18”相匹配的价格&库存,您可以联系我们找货
EDSTLZ950/18
  • 1+51.918591+6.70167
  • 10+36.8487010+4.75644
  • 25+32.3425225+4.17478
  • 50+29.5586750+3.81544
  • 100+27.27012100+3.52004
  • 250+24.90995250+3.21539
  • 500+23.54428500+3.03910
  • 1000+22.471421000+2.90062
库存:39
EDSTLZ950/18
库存:46
