PCB.MCX.F.RA.JACK.AHC.HT
    TAOGLASLIMITED
    MCX Connector Jack, Female Socket 50 Ohm Through Hole, Right Angle Solder
PCB.MCX.F.RA.JACK.AHC.HT 数据手册
SPECIFICATION Part No. : PCB.MCXFRAJ.AHC.HT Product Name : MCX (F) Jack For Right Angle PCB Mount & Crimp for 1.13/1.32/1.37 Micro Coaxial cable Feature : MCX(F) Jack R/A Thru Hole & Crimp Jack for 1.13/1.32/1.37mm cable Frequency Range: DC up to 6GHz Finish: Gold Leg Length: 3.8mm RoHS Compliant SPE-12-8-136/A/WY Page 1 of 4 1. Introduction The PCB.MCXFRAJ.AHC.HT connector is a right angle MCX(F) jack PCB mount, it has a crimp suitable for 1.13/1.32/1.37mm micro coaxial cable. The maximum thickness of PCB that the connector can be used with is 0.8mm. The connector pin is directly soldered onto pads on the PCB. Taoglas connectors are all RoHS compliant. 2. Specification ELECTRICAL Impedance 50Ω Frequency Range DC~6 GHz Working Voltage Max. ≤250 Vrms Dielectric withstanding Voltage 750 Vrms Insulation Resistance ≥10000M MΩ MECHANICAL Connector Dimension 17.8mm*10.2mm Max. Thickness PCB acceptable 0.8mm Connector Type MCX(F) Jack ENVIRONMENTAL RoHS compliant SPE-12-8-136/A/WY Page 2 of 4 3. Connector Drawing SPE-12-8-136/A/WY Page 3 of 4 Name Material Finish QTY 1 Body Brass Gold 1 2 Insulator Teflon White 1 3 Female Contact Phosphor Bronze Gold 1 4 Ferrule Brass Gold 1 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © 2012, Taoglas Ltd. SPE-12-8-136/A/WY Page 4 of 4
PCB.MCX.F.RA.JACK.AHC.HT 价格&库存
很抱歉,暂时无法提供与“PCB.MCX.F.RA.JACK.AHC.HT”相匹配的价格&库存,您可以联系我们找货
