MMCX7-P-C-HF-RA-CA3
MMCX7-P-C-HF-RA-CA3
    SAMTEC(申泰)
    特性:外壳材料:黄铜、铍铜。绝缘材料:聚四氟乙烯(PTFE)。外部接触材料:铍铜。引脚材料:黄铜。工作温度范围:-65°C 至 +125°C。阻抗:75Ω。符合 RoHS 标准。可无铅焊接
MMCX7-P-C-HF-RA-CA3 数据手册
REVISION F MMCX7-P-C-XX-RA-CA3 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] TERMINATION -CA3: CABLE (RG179) DO NOT SCALE FROM THIS PRINT GENDER -P: PLUG ORIENTATION -RA: RIGHT ANGLE TYPE -C: CABLE PLATING SPECIFICATION -HF: 30µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT -GF: 10µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT 100µ" NICKEL REMAINING PARTS (SEE TABLE 1) 1 2 7.00 .276 REF 5.25 .207 REF 2.60 .102 REF 2.70 .106 (OVER KNURL) REF 3.90 .154 REF 4.00 .157 REF 9.00 .354 REF 7.00 .276 REF 0.50 .020 REF 3 4 2.20 .087 REF 0.50 .020 REF 2.88 .113 REF UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS ANGLES X.X: 0.3 [.01] 5 X.XX: 0.13 [.005] X.XXX: 0.051 [.0020] NOTES: 1. NOTE DELETED. 2. PRODUCT TO BE PACKAGED PER PACKAGING STANDARD CO-RF-WI-3040-M. 3. NOTE DELETED. MATERIAL: * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 6:1 SHELL: BeCu CABLE BODY, PIN, FERRULE, CAP: BRASS INSULATOR: PTFE F:\DWG\MISC\MKTG\MMCX7-P-C-XX-RA-CA3-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: TRUE 75 OHM, MMCX RIGHT ANGLE PLUG, RG179 DWG. NO. MMCX7-P-C-XX-RA-CA3 BY: ALVIN W 10/08/2011 SHEET 1 OF 2 REVISION F RG 179 CABLE 1.7 .067 3.0 .118 8.0 .315 IN PROCESS 1 STRIP CABLE AND TIN INNER CONDUCTOR 2 HEAT SHRINK 20.00 .787 IN-PROCESS 2 ADD HEAT SHRINK TUBE & FERRULE END OF CABLE DIELECTRIC SHOULD SEAT AGAINST CONTACT CUP 1 'D' DETAIL 'D' SCALE 4 : 1 IN-PROCESS 3 FLARE SHIELD & ADD SUB ASSEMBLY 'E' CABLE CENTER CONDUCTOR SHOULD NOT PROTRUDE OUTSIDE CONTACT CUP AFTER FERRULE IS CRIMPED FERRULE SHOULD BE FLUSH TO SUB ASSEMBLY IN-PROCESS 4 DETAIL 'E' SCALE 6 : 1 CRIMP FERRULE (USE CRIMP HAND TOOL #CAT-RF-FER-01, AND .128" DIE SIZE) IN-PROCESS 5 SOLDER SIGNAL SOCKET 3 F:\DWG\MISC\MKTG\MMCX7-P-C-XX-RA-CA3-MKT.SLDDRW 4 IN-PROCESS 6 PRESS INSULATOR AND CAP WITH CHAMFERED EDGE INWARDS HEAT SHRINK SHOULD BE FLUSH TO SUB ASSEMBLY * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:2 IN PROCESS 7 ACTIVATE HEAT SHRINK * 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: TRUE 75 OHM, MMCX RIGHT ANGLE PLUG, RG179 DWG. NO. MMCX7-P-C-XX-RA-CA3 BY: ALVIN W 10/08/2011 SHEET 2 OF 2
MMCX7-P-C-HF-RA-CA3 价格&库存
很抱歉,暂时无法提供与“MMCX7-P-C-HF-RA-CA3”相匹配的价格&库存,您可以联系我们找货
MMCX7-P-C-HF-RA-CA3
  • 1+106.037151+13.74444
MMCX7-P-C-HF-RA-CA3
  • 5+129.834805+16.82907
  • 25+91.9660125+11.92055
  • 50+74.3357350+9.63533
  • 100+65.75794100+8.52348
库存:130
MMCX7-P-C-HF-RA-CA3
  • 1+129.701561+16.81179
库存:1398
MMCX7-P-C-HF-RA-CA3
  • 1+63.206681+8.19279
库存:416
