EDSTL955/20
EDSTL955/20
    OST
    插件,P=5mm
    接线端子 间距:5.00mm 1x20P 直插
EDSTL955/20 数据手册
EDSTL955/X (5.0 mm) EDSTLZ955/X (5.08 mm) EDSTL955/X-OE (5.0 mm) EDSTLZ955/X-OE (5.08 mm) 2-24 poles, Spacing 5.0 mm or 5.08 mm insert required no. of poles x 2-24 poles, Spacing 5.0 mm or 5.08 mm insert required no. of poles x How to order see page 5 How to order see page 5 Ratings: Rated Voltage 300 V Rated Current 15 A Rating Impulse Voltage/Dirt Level 250 V 12 A (T60) 4 kV/3 Ratings: Rated Voltage 300 V Rated Current 15 A Rating Impulse Voltage/Dirt Level 250 V 12 A (T60) 4 kV/3 Dimensions Spacing PCB Hole Diameter 5.0 mm (5.08 mm) 1.4 mm Dimensions Spacing PCB Hole Diameter 5.0 mm (5.08 mm) 1.4 mm Materials Insulating Material Flammability Class Temperature Range Contact PA/PBTP UL94 V-0 -30 C/+105 C Cu Materials Insulating Material Flammability Class Temperature Range Contact Pin PA/PBTP UL94 V-0 -30 C/+105 C Cu Color Green Color Green Screw Flange Available EDSTL956/X (5.0 mm) EDSTLZ956/X (5.08 mm) 42 ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444 42
EDSTL955/20 价格&库存
很抱歉,暂时无法提供与“EDSTL955/20”相匹配的价格&库存,您可以联系我们找货
