EDSTL950/X (5.0 mm)
EDSTLZ950/X (5.08 mm)
EDZ1710/X
2-20 poles, Spacing 3.81 mm
insert required no. of poles x
2-24 poles, Spacing 5.0 mm or 5.08 mm
How to order see page 5
Ratings:
Rated Voltage
Rated Current
Wire Size
Test Voltage
Rated Torque/ScrewSize
300 V
8A
AWG 28-16
160 V
9 A (T60)
1.5 mm 2
4 kV/3
0.4 Nm/M2
Max. Rated Cross Section
Single Wire (solid)
Stranded Wire (flexible)
Stranded wire with Ferrules
1.5 mm 2
1.0 mm 2
1.0 mm 2
Dimensions
Spacing
Stripped Length
3.81 mm
7.0 mm
Materials
Insulating Material
Flammability Class
Temperature Range
Terminal Block
Contact
PA
UL94 V-0
-30 C/+105 C
CuZn
CuSn
Ratings:
Rated Voltage
300 V
Rated Current
15 A
Rating Impulse Voltage/Dirt Level
250 V
12 A (T60)
4 kV/3
Dimensions
Spacing
PCB Hole Diameter
5.0 mm (5.08 mm)
1.4 mm
Materials
Insulating Material
Flammability Class
Temperature Range
Contact Pin
PA/PBTP
UL94 V-0
-30 C/+105 C
Cu
Color
Green
Color
Green
40
ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444
40
很抱歉,暂时无法提供与“EDSTLZ950/24”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+64.974351+8.33427
