120
DATA SHEET
ARRAY CHIP RESISTORS
YC/TC
5%, 1%
sizes
YC:102/104/122/124/162/164/248/324/158T/358L/358T
TC: 122/124/164
Product specification – August 22, 2017 V.7
RoHS compliant
2
Chip Resistor Surface Mount
YC/TC
12
102 to 358
SERIES
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC
This specification describes
YC (convex, flat) and TC (concave)
series chip resistor arrays with leadfree terminations made by thick film
process.
Both part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
YAGEO BRAND ordering code
GLOBAL PART NUMBER (PREFERSRED )
APPLICATIONS
Terminal for SDRAM and
DDRAM
Computer applications: laptop
computer, desktop computer
Consume electronic equipments:
PDAs, PNDs
Mobile phone, telecom…
YC
TC
XXXX X X X X XX XXXX L/T
(1)
(2) (3) (4) (5)
(6)
(7)
(8)
(1) SIZE
TC: 122/124/164
(2) ARRAYS OR NETWORKS
Array YC102/104/122/124/162/164/248/324: Network YC158T/YC358L/YC358T: NA
(3) TOLERANCE
FEATURES
More efficient in pick & place
application
Low assembly costs
RoHS compliant
Products with lead free
terminations meet RoHS
requirements
Pb-glass contained in electrodes
Resistor element and glass are
exempted by RoHS
Reducing environmentally
hazardous wastes
High component and equipment
reliability
Saving of PCB space
None forbidden-materials used in
products/production
Halogen Free Epoxy
F = ± 1%
J = ± 5% (for Jumper ordering, use code of J)
(4) PACKAGING TYPE
R = Paper taping reel
K = Embossed plastic tape reel
(5) TEMPERATURE COEFFICIENT OF RESISTANCE
– = Base on spec
(6) TAPING REEL
07 = 7 inch dia. Reel
13 = 13 inch dia. Reel
(7) RESISTANCE VALUE
There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point.
Detailed resistance rules show in table of “Resistance rule of global part number”.
(8) DEFAULT CODE
Letter L is the system default code for ordering only. (Note)
Letter T is the only default code for YC102.
O RDERING EXAMPLE
The ordering code of a YC122 convex chip resistor array, value 1,000 Ω
with ± 5% tolerance, supplied in 7-inch tape reel is: YC122-JR-071KL.
number
Resistance code rule
Example
0R
0R = Jumper
YC158T network, value 100,000Ω with 5% tolerance, supplied in 7-inch
tape reel is: YC158TJR-07100KL
XRXX
(1 to 9.76 Ω)
1R = 1 Ω
1R5 = 1.5 Ω
9R76 = 9.76 Ω
NOTE
XXRX
(10 to 97.6 Ω)
10R = 10 Ω
97R6 = 97.6 Ω
1. All our RSMD products meet RoHS compliant. "LFP" of the internal 2D reel label
mentions "Lead Free Process"
XXXR
(100 to 976 Ω)
100R = 100 Ω
2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of
GLOBAL PART NUMBER / 12NC can be added (both are on customer request)
XKXX
(1 to 9.76 KΩ)
1K = 1,000 Ω
9K76 = 9760 Ω
XM
(1 MΩ)
1M = 1,000,000 Ω
www.yageo.com
Aug. 22, 2017 V.7
YC/TC
SERIES
3
12
102 to 358
PHYCOMP BRAND ordering codes
Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp
brand products.
GLOBAL PART NUMBER (PREFERRED )
For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2.
TC122 series is supplied and ordered by global part number only.
12NC CODE
2350
XXX XXXXX L
(1)
(2)
(3)
Last digit of 12NC
Resistance decade (3)
(4)
PAPER / PE TAPE ON REEL (units) (2)
TYPE/ START TOL. RESISTANCE
2×0402 IN (1)
RANGE
10,000
ARV321
2350
± 5%
1 to 1 MΩ
013 11xxx
013 12xxx
ARV322
2350
± 1%
10 to 1 MΩ
013 2xxxx
013 3xxxx
Jumper
2350
0Ω
013 91001
50,000
(1) The resistors have a 12-digit ordering code starting with 2350.
(2) The subsequent 4 or 5 digits indicate the resistor tolerance and
packaging.
(3) The remaining 4 or 3 digits represent the resistance value with the
last digit indicating the multiplier as shown in the table of
“Last digit of 12NC”.
(4) "L" is optional symbol
(Note) .
Last digit
0.01 to 0.0976 Ω
0.1 to 0.976 Ω
1 to 9.76 Ω
8
10 to 97.6 Ω
9
100 to 976 Ω
1
1 to 9.76 KΩ
2
10 to 97.6 KΩ
3
100 to 976 KΩ
4
1 to 9.76 MΩ
5
10 to 97.6 MΩ
6
Example:
7
0.02 Ω
0200 or 200
0.3 Ω
3007 or 307
O RDERING EXAMPLE
1Ω
1008 or 108
The ordering code of a ARV321 resistor, value 1,000Ω with ± 5%
tolerance, supplied in tape of 10,000 units per reel is: 235001311102(L)
or YC122-JR-071KL.
33 KΩ
3303 or 333
10 MΩ
1006 or 106
NOTE
1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process"
2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART
www.yageo.com
Aug. 22, 2017 V.7
YC/TC
SERIES
4
12
102 to 358
MARKING
YC102
No marking
Fig. 1
YC122
No marking
Fig. 2
YC104
No marking
Fig. 3
YC124 / 162 / 164 / 324
1-Digit marking
Fig. 4 Jumper=0Ω
E-24 series: 3 digits, 5%
2
Fig. 4-1 Value=240KΩ
First two digits for significant figure and 3rd digit for number of zeros
YC248
1-Digit marking
Fig. 5 Jumper=0Ω
2
Fig. 5-1 Value=240KΩ
YC158T/358L/358T
2
Fig. 6 Value=24Ω
Fig. 6-1
Value=240KΩ
TC122
No marking
Fig. 7
TC124
No marking
Fig. 8
www.yageo.com
Aug. 22, 2017 V.7
YC/TC
SERIES
5
12
102 to 358
TC164
1-Digit marking
Fig. 9 Jumper=0Ω
2
Fig. 9-1 Value=240KΩ
For further marking information, please refer to data sheet “Chip resistors marking”.
CONSTRUCTION
The resistor is constructed on top
of a high-grade ceramic body.
Internal metal electrodes are added
on each end to make the contacts to
the thick film resistive element. The
composition of the resistive element
is a noble metal imbedded into a
glass and covered by a second glass
to prevent environment influences.
The resistor is laser trimmed to the
rated resistance value. The resistor
is covered with a protective epoxy
coat, finally the two external
terminations (matte tin on Nibarrier) are added as shown in Fig.9.
OUTLINES
Fig. 10 Chip resistor outlines
www.yageo.com
Aug. 22, 2017 V.7
YC/TC
SERIES
102 to 358
6
12
SCHEMATIC
Fig. 11 Equivalent circuit diagram
Note: 1. YC102/104 is flat type
For dimension, please refer to Table 1
Side view for all types
YC102_ T
YC 122/162
TC 122
YC 104/124/164/324
158/358/248
TC 124/164
unit: mm
Fig. 12 YC/TC122 series chip resistors dimension
Note: (1) YC102/104 is flat type
www.yageo.com
Aug. 22, 2017 V.7
YC/TC
SERIES
7
12
102 to 358
DIMENSIONS
Table 1
TYPE
YC102
H / H1 / HW
YC104
YC122
YC124
YC162
YC164
YC248
YC324
B
P
L
T
W1
W2
H : 0.25 ± 0.10
0.15 ± 0.10
0.55 ± 0.10
0.80 ± 0.10
0.35 ± 0.10
0.15 ± 0.10
0.60 ± 0.10
H : 0.20 ± 0.10
0.15 ±0.05
0.40 ±0.10
1.40 ±0.10
0.35 ±0.10
0.15 ±0.10
0.60 ±0.10
H : 0.21+0.10 / -0.05
HW : 0.35 ± 0.10
H: 0.45 ± 0.05
H1: 0.30 ± 0.05
0.20 ±0.10
0.67 ±0.05
1.00 ±0.10
0.30 ±0.10
0.25 ±0.10
1.00 ±0.10
0.20 ±0.15
0.50 ±0.05
2.00 ±0.10
0.45 ±0.10
0.30 ±0.15
1.00 ±0.10
H : 0.30 ± 0.10
HW : 0.65 ± 0.15
0.30 ±0.10
0.80 ±0.05
1.60 ±0.10
0.40 ±0.10
0.30 ±0.10
1.60 ±0.10
0.30 ±0.15
0.80 ±0.05
3.20 ±0.15
0.60 ±0.10
0.30 ±0.15
1.60 ±0.15
0.30 ±0.15
0.50 ±0.05
4.00 ±0.20
0.45 ±0.10
0.40 ±0.15
1.60 ±0.15
0.50 ±0.20
1.27 ±0.05
5.08 ±0.20
0.60 ±0.10
0.50 ±0.15
3.20 ±0.20
H : 0.65 ±0.05
H1: 0.50 ±0.15
H : 0.45 ±0.05
H1: 0.30 ±0.05
H : 1.10 ±0.15
H1: 0.90 ±0.15
TC122
H : 0.30 ±0.05
0.25 ±0.15
0.50 ±0.05
1.00 ±0.10
0.30 ±0.10
0.25 ±0.15
1.00 ±0.10
TC124
H : 0.30 ±0.10
0.20 ±0.10
0.50 ±0.05
2.00 ±0.10
0.40 ±0.10
0.25 ±0.10
1.00 ±0.10
TC164
H : 0.50 ± 0.15
0.30 ±0.15
0.80 ±0.05
3.20 ±0.15
0.60 ±0.10
0.30 ±0.15
1.60 ±0.15
YC158T
H : 0.45±0.05
H1: 0.32± 0.05
0.30 ±0.15
0.64 ±0.05
3.20 ±0.20
0.60 ±0.10
0.35 ±0.15
1.60 ±0.15
YC358L
YC358T
H : 1.10±0.15
0.50 ±0.15
1.27 ±0.05
6.40 ±0.20
0.60 ±0.10
0.50 ±0.15
3.20 ±0.20
H1: 0.90±0.15
www.yageo.com
Aug. 22, 2017 V.7
YC/TC
SERIES
8
12
102 to 358
ELECTRICAL CHARACTERISTICS
Table 2
TYPE
POWER OPERATING
P70
TEMP. RANGE
YC102
1/32W
-55°C to +125°C
MWV
RCOV
DWV
RESISTANCE RANGE &
TOLERANCE
T. C. R.
15V
30V
30V
E24 ± 5% 10Ω ≤ R ≤ 1MΩ
E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ
Jumper < 0.05Ω
Jumper criteria
(unit: A)
Rated current 0.5
Max. current 1.0
± 200 ppm/°C
YC104
1/32W
-55°C to +125°C
12.5V
25V
25V
Jumper < 0.05Ω
YC122
1/16W
-55°C to +155°C
50V
100V
100V
E24 ± 5% 1Ω ≤ R ≤ 1MΩ
E24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ
Jumper < 0.05Ω
YC124
1/16W
-55°C to +155°C
25V
50V
100V
Jumper < 0.05Ω
YC162
1/16W
-55°C to +155°C
50V
100V
100V
E/24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ
Jumper < 0.05Ω
YC164
1/16W
-55°C to +155°C
50V
100V
100V
Jumper < 0.05Ω
Rated current 1.0
Max. current 2.0
YC248
1/16W
-55°C to +155°C
50V
100V
100V
Jumper < 0.05Ω
Rated current 2.0
Max. current 10.0
YC324
1/8W
-55°C to +155°C
200V
500V
500V
TC122
1/16W
-55°C to +125°C
50V
100V
100V
Jumper < 0.05Ω
Rated current 0.5
Max. current 1.0
Rated current 0.5
Max. current 1.0
1Ω ≤ R ≤ 10Ω
± 250 ppm/°C Rated current 1.0
10Ω ≤ R ≤ 1MΩ Max. current 2.0
± 200 ppm/°C
Rated current 1.0
Max. current 2.0
± 200 ppm/°C
Rated current 1.0
Max. current 1.5
TC124
1/16W
-55°C to +125°C
50V
100V
100V
Jumper < 0.05Ω
TC164
1/16W
-55°C to +155°C
50V
100V
100V
Jumper < 0.05Ω
YC158T
1/16W
-55°C to +155°C
25V
50V
50V
E24 ± 5%
10Ω ≤ R ≤
100KΩ
YC358L
YC358T
1/16W
-55°C to +155°C
50V
100V
100V
E24 ± 5%
10Ω ≤ R ≤
330KΩ
Rated current 1.0
Max. current 1.5
Rated current 1.0
Max. current 2.0
FOOTPRINT AND SOLDERING PROFILES
For recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”.
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
YC102/
104
YC/TC
122
YC/TC
124
YC162
7" (178mm)
10,000
10,000
10,000
13" (254mm)
50,000
50,000
40,000
PACKING STYLE
PACKING STYLE
Paper taping reel ( R )
Embossed taping reel ( K) 7" (178mm)
YC/TC
164
YC248
YC324 YC158T
YC358L
YC358T
5,000
5,000
5,000
5,000
20,000
20,000
4,000
4,000
4,000
NOTE
1. For tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”.
www.yageo.com
Aug. 22, 2017 V.7
YC/TC
SERIES
102 to 358
9
12
FUNCTIONAL DESCRIPTION
OPERATING TEMPERATURE RANGE
YC102/104/122/162, TC122/124 Range:
-55℃ to +125℃ (Fig.13)
YC124/164/248/324/158T/358L/358T, TC164 Range:
-55℃ to +155℃(Fig.14)
POWER RATING
Each type rated power at 70℃
YC102/104 = 1/32 W
YC122/124/162/164/248/158T/358L/358T = 1/16 W
YC324 = 1/8 W
TC122/124/164 = 1/16 W
Fig. 13 Maximum dissipation (P) in percentage of rated power as a
function of the operating ambient temperature (T amb )
R ATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V= (PxR)
or max. working voltage whichever is less
Where
V=Continuous rated DC or
AC (rms) working voltage (V)
P=Rated power (W)
R=Resistance value (Ω )
Fig. 14 Maximum dissipation (P) in percentage of rated power as a
www.yageo.com
Aug. 22, 2017 V.7
YC/TC
SERIES
10
12
102 to 358
TESTS AND REQUIREMENTS
Table 4 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
Life/
Operational Life/
Endurance
MIL-STD-202G-method 108A
1,000 hours at 70± 5 °C applied RCWV
1.5 hours on, 0.5 hour off, still air required
High Temperature
Exposure/
Endurance at
Upper Category
Temperature
IEC 60115-1 4.25.1
REQUIREMENTS
± (2%+0.05 Ω)
