EDZ1550/11
EDZ1550/11
    OST
    P=3.81mm
    接线端子 间距:3.81mm 1x11P 螺钉安装
EDZ1550/11 数据手册
ED1550/X (3.5 mm) EDZ1550/X (3.81 mm) EDZ1700/X 2-20(16) poles, Spacing 3.5 mm or 3.81 mm insert required no. of poles x 2-20 poles, Spacing 3.81 mm insert required no. of poles x How to order see page 5 Ratings: Rated Voltage Rated Current Wire Size Test Voltage Rated Torque/ScrewSize 160 V 9 A (T60) 1.5 mm 2 4 kV/3 0.4 Nm/M2 Ratings: Rated Voltage 300V Rated Current 8A Wire Size AWG 28-16 Rating Impulse Voltage/Dirt Level Rated Torque/Screw Size 160 V 9 A (T60) 1.5 mm 2 4 kV/3 0.4 Nm/M2 Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 1.5 mm 2 1.0 mm 2 1.0 mm 2 Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 1.5 mm 2 1.0 mm 2 1.0 mm 2 Dimensions Spacing Stripped Length 3.5 mm (3.81 mm) 7.0 mm Dimensions Spacing Stripped Length 3.81 mm 7.0 mm Materials Insulating Material Flammability Class Temperature Range Terminal Block Contact PA UL94 V-0 -30 C/+105 C CuZn CuSn Materials Insulating Material Flammability Class Temperature Range Terminal Block Contact PA UL94 V-0 -30 C/+105 C CuZn CuSn Color Green 39 How to order see page 5 300 V 8A AWG 28-16 Color Green ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444 39
EDZ1550/11 价格&库存
很抱歉,暂时无法提供与“EDZ1550/11”相匹配的价格&库存,您可以联系我们找货
