RACF164DJT220K
RACF164DJT220K
    SEI
    1206(3216公制),凹面,长边端子
    排阻/电阻网络 1206 220KΩ ±5% ±200ppm/℃
RACF164DJT220K 数据手册
RACF Series Stackpole Electronics, Inc. Concave Termination Chip Resistor Array Resistive Product Solutions Features: • • • • Product will be discontinued - not recommended for new designs Last time buy December 1, 2020 For more information please see our PDN here RAVF series of convex arrays is recommended as replacement Electrical Specifications Type / Code / # of Elements / Circuit Type Power Rating (W) (per element) @ 70ºC RACF102D 0.063 25 50 RACF104D 0.063 25 50 Maximum Working Maximum Overload Voltage (V) Voltage (V) RACF164D 0.063 50 RACF324D 0.125 200 RACF408M 0.063 25 RACF648N 0.063 50 RACF648R 0.063 50 Note: (1) Lesser of √ P*R or maximum working voltage. 100 400 50 100 100 TCR (ppm/ºC) ± 650 ± 250 ± 400 ± 200 ± 200 ± 200 ± 200 ± 200 ± 200 Ohmic Range (Ω) and Tolerance 1% 2% 3 - 9.88 10 - 1M 1 - 9.88 10 - 1M 22 - 1M 5% 10 - 1M - 10 - 1M 22 - 1M 22 - 1M 22 - 1M Performance Characteristics Test Test Results (JIS C 5202) Load Life in Moisture Temperature cycle Load Life Resistance to Soldering heat Terminal Adhesion Short Time Overload ± 3% ± 1% ± 3% ± 1% ± 1% ± 2% Operating Temperature Range: RACF102D and RACF104D: -55ºC to 155ºC All other types: -55ºC to 125ºC Power Derating Curve: Rev Date: 03/26/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com RACF Series Stackpole Electronics, Inc. Concave Termination Chip Resistor Array Resistive Product Solutions Schematics Isolated Circuit - D Bussed Circuit - M Bussed Circuit - N Bussed Circuit - R Terminations 2 Resistors / 4 Terminations (D) 4 Resistors / 8 Terminations (D) 8 Resistors / 10 Terminations (N/R) 8 Resistors / 10 Terminations (M) Mechanical Specifications Type / Code / # of Elements / Circuit Type RACF102D RACF104D RACF164D RACF324D RACF408M RACF648N RACF648R L Body Length 0.039 1.00 0.079 2.00 0.126 3.20 0.200 5.08 0.157 4.00 0.252 6.40 0.252 6.40 ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 W Body Width 0.039 1.00 0.039 1.00 0.063 1.60 0.118 3.00 0.083 2.10 0.122 3.10 0.122 3.10 ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.006 0.15 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 H Body Height 0.012 0.30 0.016 0.40 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.004 0.10 1.000 0.10 0.006 0.15 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 P Element Spacing 0.020 0.50 0.020 0.50 0.031 0.80 0.050 1.27 0.031 0.80 0.050 1.27 0.050 1.27 Q Termination Width 0.012 ± 0.004 0.30 ± 0.10 0.012 ± 0.004 0.30 ± 0.10 0.016 ± 0.008 0.40 ± 0.20 0.031 ± 0.004 0.80 ± 0.10 0.020 ± 0.008 0.50 ± 0.20 0.028 ± 0.008 0.70 ± 0.20 0.028 ± 0.008 0.70 ± 0.20 D Bottom Termination 0.010 ± 0.004 0.25 ± 0.10 0.010 ± 0.004 0.25 ± 0.10 0.016 ± 0.008 0.40 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 A Top Termination 0.007 ± 0.004 0.18 ± 0.10 0.006 ± 0.004 0.15 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.022 ± 0.008 0.55 ± 0.20 0.010 ± 0.008 0.25 ± 0.20 0.014 ± 0.006 0.35 ± 0.15 0.014 ± 0.006 0.35 ± 0.15 E End Termination 0.012 ± 0.008 0.30 ± 0.20 - Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm Recommended Pad Layout Type A B P Q1 Q2 Unit RACF102D 0.020 0.50 0.079 2.00 0.020 0.50 0.011 0.28 0.009 0.22 inches mm Rev Date: 03/26/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RACF Series Stackpole Electronics, Inc. Concave Termination Chip Resistor Array Resistive Product Solutions Recommended Pad Layout Type A B P Q1 Q2 Unit RACF104D 0.020 0.50 0.079 2.00 0.020 0.50 0.011 0.28 0.009 0.22 inches mm Type A B P Q1 Q2 Unit 0.031 0.80 0.087 2.20 0.102 2.60 0.165 4.20 0.031 0.80 0.050 1.27 0.020 0.50 0.028 0.70 0.012 0.30 0.022 0.57 inches mm inches mm RACF164D RACF324D Type RACF408M Type RACF648N / 648R A 0.039 1.00 B 0.118 3.00 A 0.031 0.80 Rev Date: 03/26/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. D 0.039 1.00 B 0.122 3.10 3 E 0.134 3.40 P 0.031 0.80 P 0.050 1.27 Q1 0.020 0.50 Q1 0.028 0.70 Unit inches mm Unit inches mm www.seielect.com marketing@seielect.com RACF Series Stackpole Electronics, Inc. Concave Termination Chip Resistor Array Resistive Product Solutions RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Package / Standard Termination Series RoHS Type Compliant Description Thick Film Surface Mount Chip Resistor Array Concave Terminations Note (1): RoHS Compliant by means of exemption 7c-I. RACF SMD YES(1) Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) 100% Matte Sn over Ni Jan-04 04/01 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 R A C F 1 6 4 D J T 1 0 K 0 Product Series Concave RACF RoHS Power Rating Code W 102D 0.063 104D 0.063 164D 0.063 324D 0.125 408M 0.063 648N 0.063 648R 0.063 Tolerance Code Tol Value F 1% E24, E96 G 2% E24 J 5% Z jumper Code T Packaging Description Size 102D, 104D Reel - Paper Tape 164D 324D, 408M Reel - Plastic Tape 648N, 648R Quantity 10000 5000 4000 Resistance Value Four characters with the multiplier used as the decimal holder. 1 ohm = 1R00 100 Kohm = 100K 1 Mohm = 1M00 Zero ohm jumper = 0R00 D = Isolated M, N, R = Bussed Rev Date: 03/26/2020 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com
RACF164DJT220K AI解析
物料型号:RACF系列,包括RACF102D, RACF104D, RACF164D, RACF324D, RACF408M, RACF648N, RACF648R。
器件简介:这些是Stackpole Electronics, Inc.提供的厚膜表面贴装芯片电阻阵列,具有凹端终止。
引脚分配:根据电阻阵列的类型,有2个电阻/4个引脚(D),4个电阻/8个引脚(D),8个电阻/10个引脚(N/R),10个电阻/10个引脚(M)。
参数特性:包括功率额定值、最大工作电压、最大过载电压、温度系数、欧姆范围和公差。
功能详解:文档提供了环境测试结果,如湿热寿命、温度循环、负载寿命、耐焊热性和端子粘附性。
应用信息:产品将被停产,不建议新设计使用。最后一次购买日期为2020年12月1日。推荐使用RAVF系列凸阵列作为替代品。
封装信息:提供了机械规格,包括体长、体宽、体高、元件间距、终止宽度等,以及推荐的焊盘布局。
*介绍内容由AI识别生成
RACF164DJT220K 价格&库存
很抱歉,暂时无法提供与“RACF164DJT220K”相匹配的价格&库存,您可以联系我们找货
