EM502504
EM502504
    EATON(伊顿)
    TERM BLOCK HDR 4POS VERT 5MM
EM502504 数据手册
Plug & Header EM5025 Series EuroMag Terminal Blocks Header (Mates with EM5015 Series); 5.00 Centers EM502512 SPECIFICATIONS Rating: 15A, 300V Center Spacing: 0.197” (5.00mm) Housing Material: Black UL 94V0 Thermoplastic Contact Material: Tin-Plated Brass Operating Temperature: 120°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.059" (1.50mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified EM502506 WIRE ENTRY WIRE ENTRY Mating orientations Poles L (mm) Poles L (mm) Dimensions - in (mm) 2 3 4 5 6 7 8 9 10 11 12 13 Compliance References Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Pluggable Terminal Blocks 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 0.05 DIA. (1.3) 0.197 (5.00) 0.49 (12.5) 0.08 (2.0) 0.11 (2.8) L 0.18 (4.5) To convert to inches, divide by 25.4 EM5025 ø1.50 (ø0.059") PCB Hole Layout 580 (0.197") Part Numbering System En Mn 5n 0n 2n 5 nn n Series # of Poles Mating Plug: EM5015 pg. 103 02 to 24 For additional product information, visit www.eaton.com/connectors 104
EM502504 价格&库存
很抱歉,暂时无法提供与“EM502504”相匹配的价格&库存,您可以联系我们找货
