Plug & Header
Compliance
References
Edge Connectors,
One-Sided Boards
EuroMag Series
Terminal Blocks:
Single Row
EuroMag Series PCB Mount Pluggable Terminal Blocks
EM2535 Series
EuroMag Terminal Blocks
Header (Mates with EM2525,
EM3105 Series); 5.00 Centers
EM253505VC
SPECIFICATIONS
Rating: 16A, 300V
Center Spacing: 0.197” (5.00mm)
Consult factory for 0.394” (10.00mm)
Housing Material: UL rated 94V0 Thermoplastic
Contact Material: Brass Tin-Plated
Operating Temperature: 105°C (221°F) max., -40°C
(-40°F) min.
Recommended PCB Hole Diameters: 0.055” (1.40mm)
Construction: Mold-to-Length
Agency Information:
File E62622; CE Certified
EM253508HO
Dimensions - in (mm)
VERTICAL - CLOSED
L
0.47
(12.0)
0.17
(4.2)
0.039
(1.00)
Position
02
03
04
05
06
07
08
09
10
11
12
13
Open
L (mm)
Closed
L (mm)
Position
Open
L (mm)
Closed
L (mm)
10.0
15.0
20.0
25.0
30.0
35.0
40.0
45.0
50.0
55.0
60.0
65.0
12.0
17.0
22.0
27.0
32.0
37.0
42.0
47.0
52.0
57.0
62.0
67.0
14
15
16
17
18
19
22
23
24
70.0
75.0
80.0
85.0
90.0
95.0
100.0
105.0
110.0
115.0
120.0
72.0
77.0
82.0
87.0
92.0
97.0
102.0
107.0
112.0
117.0
122.0
0.197
(5.00)
0.14
(3.5)
0.039
(1.00)
0.11
(2.7)
9.1
(0.36)
0.15
(3.8)
HORIZONTAL - OPEN
0.039
(1.0)
L
EM2535VC
To convert to inches, divide by 25.4
0.47
(12.0)
0.197
(5.00)
0.10
(2.5)
0.17
(4.2)
0.08
(2.0)
0.039
(1.0)
0.36
(9.1)
Part Numbering System
En
Mn
2n
5n
3n
5 nn
n
Series
# of Positions
Orientations
n
n
02 to 24
H - horizontal
V - vertical
O - open
C - closed
Side Base
For additional product information, visit www.eaton.com/connectors
Mating Plugs: EM2525 pg. 85
EM2485 pg. 86
EM3105 pg. 87
88
很抱歉,暂时无法提供与“EM253502VO”相匹配的价格&库存,您可以联系我们找货
