EM253502HO
EM253502HO
    EATON(伊顿)
    插件
EM253502HO 数据手册
Plug & Header Compliance References Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Pluggable Terminal Blocks EM2535 Series EuroMag Terminal Blocks Header (Mates with EM2525, EM3105 Series); 5.00 Centers EM253505VC SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.197” (5.00mm) Consult factory for 0.394” (10.00mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.055” (1.40mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified EM253508HO Dimensions - in (mm) VERTICAL - CLOSED L 0.47 (12.0) 0.17 (4.2) 0.039 (1.00) Position 02 03 04 05 06 07 08 09 10 11 12 13 Open L (mm) Closed L (mm) Position Open L (mm) Closed L (mm) 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 12.0 17.0 22.0 27.0 32.0 37.0 42.0 47.0 52.0 57.0 62.0 67.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 72.0 77.0 82.0 87.0 92.0 97.0 102.0 107.0 112.0 117.0 122.0 0.197 (5.00) 0.14 (3.5) 0.039 (1.00) 0.11 (2.7) 9.1 (0.36) 0.15 (3.8) HORIZONTAL - OPEN 0.039 (1.0) L EM2535VC To convert to inches, divide by 25.4 0.47 (12.0) 0.197 (5.00) 0.10 (2.5) 0.17 (4.2) 0.08 (2.0) 0.039 (1.0) 0.36 (9.1) Part Numbering System En Mn 2n 5n 3n 5 nn n Series # of Positions Orientations n n 02 to 24 H - horizontal V - vertical O - open C - closed Side Base For additional product information, visit www.eaton.com/connectors Mating Plugs: EM2525 pg. 85 EM2485 pg. 86 EM3105 pg. 87 88
EM253502HO 价格&库存
很抱歉,暂时无法提供与“EM253502HO”相匹配的价格&库存,您可以联系我们找货
