3140-F170-P7T1-SGRX-5A
    E-T-A
3140-F170-P7T1-SGRX-5A 数据手册
ENGINEERING TECHNOLOGY Thermal Overcurrent Circuit Breaker 3140 Description Four pole switch or three pole switch/thermal circuit breaker (S-type TO CBE to EN 60934) with trip-free mechanism and red/green two button operation. Designed for snap-in panel mounting. Integral splash water protection to meet protection degree IP 66 in the operating area (option). Optional with under voltage release module. Complies with CBE standard EN 60934 (IEC 60934). Typical applications High-pressure cleaners, shredders, pumps, power saws, electric tools, motors, processing systems. 1 3140 Approval logos Technical data Conformity REACH 2213 For further details please Voltage rating Current rating range Typical life 3 AC 415 V: 0.1...14 A 15...16 A 3 AC 415 V 0.1...14 A 15...16 A Ambient temperature Insulation co-ordination (IEC 60664 and 60664A) Dielectric strength (IEC 60664 and 60664A) operating area between poles (3-pole) Insulation resistance Interrupting capacity Icn Interrupting capacity (UL 1077) Degree of protection (IEC 60529/DIN 40050) Vibration Shock Corrosion Humidity Mass www.e-t-a.de see: http://www.e-t-a.de/ti_e 3 AC 415 V 0.1...16 A 3-pole 10,000 operations at 1 x IN, inductive 10,000 operations at 1 x IN, resistive 4-pole 10,000 operations at 1 x IN, inductive 10,000 operations at 1 x IN, resistive -30...+60 °C (-22...+140 °F) rated impulse pollution withstand voltage degree 2.5 kV 2 reinforced insulation in operating area test voltage AC 3,000 V AC 1,500 V > 100 MΩ (DC 500 V) 0.1...2 A 10 x IN 2.5...16 A 150 A IN UN 3- and 4-pole 0.1...16 A AC 250 V 5,000 A operating area IP40 (IP66 with water splash protection) terminal area IP00 5 g (57-500 Hz) ± 0.38 mm (10-57 Hz) to IEC 60068-2-6, test Fc, 10 frequency cycles/axis 20 g (11 ms) to IEC 60068-2-27, test Ea 96 hours at 5 % salt mist, to IEC 60068-2-11, test Ka 240 hours at 95 % RH, to IEC 60068-2-78, test Cab approx. 68 1 ENGINEERING TECHNOLOGY Thermal Overcurrent Circuit Breaker 3140 Approvals Standard current ratings and typical internal resistance values Prüfstelle Prüfnorm Nennspannung Nennstrombereich UL UL1077 AC 250 V DC 50 V 0,1...16 A (3-4 pole) VDE IEC/EN 60934 3 AC 415 V 0,1 A…16 A (3-4 pole) CQC GB 17701 AC 240/415 V 0,1 A…16 A (3-4 pole) CSA CSA C22.2, No. 235 AC 250 V DC 50 V 0,1 A...16 A (3-4 pole) 1 Ordering information Type No. 3140 four pole switch or three pole switch/circuit breaker Mounting F snap in frame Frame 1 standard 2 splash water protected version Number of poles 3 3-pole, thermally protected 7 4-pole, thermally protected on 3 poles only Frame mounting 0 panel thickness 1-6.35 mm (.04-.25 in) Terminal design P7 blade terminals 2x2.8x0.8 mm (QC 2x.110), DIN 46244-C H7 as P7, additionally flat-head screw ISO 7045-M3.5 with +/- slot at terminal .1 (required with X3140-U) Characteristic curve T1 thermal Switch style S 2 push buttons (ON/OFF) Switch colour GRX green/red Current rating range 0.1...16 A 3140 - F 1 3 0 - P7 T1 - S GRX - 10 A Current rating (A) 0.1 0.2 0.3 0.4 0.5 0.6 0.8 1 1.2 1.5 2 2.5 3 Internal resistance per pole (Ω) 94 24 12 5.30 4.20 2.90 1.50 0.9 0.80 0.45 0.27 0.0785 0.0595 Current rating (A) 3.5 4 4.5 5 6 7 8 10 12 14 15 16 Internal resistance per pole (Ω) 0.0595 0.0435 0.0325 0.0325 0.0215 0.0165 0.0125 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 ordering example Please be informed that we have minimum ordering quantities to be observed. All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 2 www.e-t-a.de 2213 Undervoltage Release Module X3140-U...for circuit breaker 3140 ENGINEERING TECHNOLOGY Dimensions Internal connection diagrams 3-pole thermally protected OFF-position 19.9 41.3 Unprotected pole (4-pole version, not applicable for 3-pole version) 12.7 10.7 line I.I II.I III.I line I.I II.I III.I IV.I load I.2 II.2 III.2 load I.2 II.2 III.2 IV.3 1 Typical time/current characteristics 10 flat head screw M3,5 tightening torque max. 0,8 Nm 10.7 4-pole 3-poles thermally protected 21.1 13.4 17.7 3.5 blade terminal DIN 46244-C-Ms-S 3 15.5 0.1…2 A 44.5 60 °C 10000 41 23 °C -30 °C 54.2 Trip time in seconds 1000 -0.4 -0.2 61.6 Panel cut-out 100 10 panel thickness 1-6.35 mm max. R2 ±0.05 1 min. 2.5 50.5+0.3 0.1 0.8 1 1.4 2 4 6 8 10 ...times rated current 45+0.2 3 0. .R ax m 20 40 2.5…16 A 60 °C 10000 23 °C Edges of working parts: ISO13715 -30 °C Trip time in seconds 1000 Installation drawing When installing the circuit breaker apply pressure on bezel only operating area 100 10 1 15,5 10 7 7 0.1 4 6 8 10 0.8 1 1.4 2 ...times rated current 8 7 10 20 40 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section Technical information. Ambient temp. °F °C -22 -30 -4 -20 +14 -10 +32 0 +73.4 +23 +104 +40 +122 +50 +140 +60 Derating factor 0.8 0.76 0.84 0.92 1 1.08 1.16 1.24 mounting area This is a metric design and millimeter dimensions take precedence ( mm ) inch 2213 www.e-t-a.de 3 ENGINEERING TECHNOLOGY Thermal Overcurrent Circuit Breaker 3140 Description Dimensions A module suitable for all versions of type 3140 to trip the main switch/ circuit breaker mechanism in the event of loss of voltage of the connected phases. When the voltage is restored the switch must be reset to reconnect the load, thereby avoiding the safety hazards associated with automatic re-starting of machinery. Note: Basic unit 3140-... must be fitted with -H7 or -G7 screw terminals. 19.9 17.7 74.8 10 Typical applications 33.5 Machines such as power tools, industrial equipment and domestic appliances where automatic restart after restoration of power could be dangerous (EU Machinery Directive). 6.6 21 Ordering information 1 blade terminal Ordner number X3140-U01... 44.5 Type No. X3140 Module for type 3140 Function U undervoltage release module Terminal design 00 standard (without separate connections) 01 one blade terminal 2.8x0.8 (QC .110) Voltage ratings 00 AC 400 V 50/60 Hz 03 DC 24 V 09 AC 230 / 240 V 50/60 Hz Assembly status M module mounted to the circuit breaker 23.5 flat head screw M3.5 tightening torque max. 0.8 Nm blade terminal 6.3x0.8 61,6 Internal connection diagrams X3140 - U 00 00 M ordering example X3140-U00 line 2.1 1.1 Technical data 1.1 2.2 load 3.2 1.2 line 3.1 4.1 4.2 2.2 3.2 load X3140-U01 1.1 line A2 2.1 3.1 1.1 1.2 2.2 load 3.2 1.2 line A2 2.1 3.1 4.1 3.2 4.2 U< 1.2 U< Mass AC 400 V 50/60 Hz; AC 230 V; DC 24 V +10%/-15% approx. 2.0 mA 0.2 x UN < U < 0.7 x UN (at a rated voltage of AC 400 V the device may release at 280 V and must release at 80 V) t < 20 ms ≥ 85 % UN -30...+60 °C (-22...+140 °F) 5 g (57-500 Hz) ± 0.38 mm (10-57 Hz) to IEC 60068-2-6, test Fc 10 frequency cycles/axis 20 g (11 ms) to IEC 60068-2-27, test Ea 48 hours at 5 % salt mist, to IEC 60068-2-11, test Ka 240 hours at 95 % RH to IEC 60068-2-78, test Cab approx. 90 g (complete assembly) 2.1 U< 3.1 U< Voltage ratings Voltage tolerance Current consumption Release values Release delay Latch-in values Ambient temperature Vibration Shock Corrosion Humidity blade terminal 2.8x0.8 41 54,2 1 41.3 US patent number: US 6,714,396 B2 2.2 load Approvals (complete circuit breaker/module assembly) Authority Standard Rated voltage VDE IEC/EN 60934 AC 42...400 V DC 24 V This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 4 www.e-t-a.de 2213
3140-F170-P7T1-SGRX-5A 价格&库存
很抱歉,暂时无法提供与“3140-F170-P7T1-SGRX-5A”相匹配的价格&库存,您可以联系我们找货
