EM2575 Series
EuroMag Terminal Blocks
Header (Mates with EM2565,
EM3108 Series); 5.08 Centers
EM257512HC
SPECIFICATIONS
Rating: 16A, 300V
Center Spacing: 0.20” (5.08mm)
Consult factory for 0.40” (10.16mm)
Housing Material: UL rated 94V0 Thermoplastic
Contact Material: Brass Tin-Plated
Operating Temperature: 105°C (221°F) max., -40°C
(-40°F) min.
Recommended PCB Hole Diameters: 0.055" (1.40mm)
Construction: Mold-to-Length
Agency Information:
File E62622; CE Certified
2
3
4
5
6
7
8
9
10
11
12
13
10.16
15.24
20.32
25.40
30.48
35.56
40.64
45.72
50.80
55.88
60.96
66.04
12.08
17.16
22.24
27.32
32.40
37.48
42.66
47.64
62.72
67.80
62.88
67.96
Poles
Open
L (mm)
Closed
L (mm)
14
15
16
17
18
19
22
23
24
71.12
76.20
81.28
86.36
91.44
96.52
101.60
106.68
111.76
116.84
121.92
73.04
78.12
83.20
88.28
93.36
98.44
103.52
105.60
113.68
118.76
123.84
EM257506VO
Dimensions - mm (in)
HORIZONTAL OPEN
HORIZONTAL CLOSED
L+
_0.5
L+
_0.5
12+
_0.3
(0.472")
8.3+
_0.3
(0.327")
1.8+
_0.3
(0.071")
To convert to inches, divide by 25.4
1+
_0.1
(0.039")
1.00+
_0.1
(0.039")
5.08+
_0.1
(0.200")
5.08+
_0.1
(0.200")
Ø1.5
(Ø 0.059")
12+
_0.3
(0.472")
Closed
L (mm)
EM257512VC
4.5+
_0.3
(0.177")
Poles
Open
L (mm)
EM257506HO
1.8+
_0.3
(0.071")
PCB Hole Layout
5.08+
_0.1
(0.200")
VERTICAL CLOSED
VERTICAL OPEN
12±0.3
(0.472")
5.08±0.1
(0.200")
L±0.5
L±0.5
8.3±0.3
(0.327")
1±0.1
(0.039")
1.00±0.1
[0.039]
3.8±0.3
(0.150")
4.5±0.3
(0.177")
Ø1.5
(Ø 0.059")
5.08±0.1
(0.200")
8.3±0.3
(0.327")
PCB Hole Layout
3.8±0.3
(0.150")
Plug & Header
Compliance
References
Edge Connectors,
One-Sided Boards
EuroMag Series
Terminal Blocks:
Single Row
EuroMag Series PCB Mount Pluggable Terminal Blocks
Part Numbering System
En
Mn
2n
5n
7n
5 nn
n
Series
# of Poles
02 to 24
n
n
H - horizontal
V - vertical
O - open
C - closed
Orientation
Side Base
Mating Plugs: EM2565 pg. 89
EM2488 pg. 90
EM3108 pg. 91
For additional product information, visit www.eaton.com/connectors
92
很抱歉,暂时无法提供与“EM257503VO”相匹配的价格&库存,您可以联系我们找货
