9510-G111-J1F1-B2R2B1-5A 数据手册
Simulator switch, magnetic operation 9510-...
Description
Single pole, magnetic simulator switch with extremely low trip current
and precise trip behavior. Available with threadneck mounting or
flange mounting. Actuation is via a push-pull mechanism. Push
button marking for simulation of various current ratings is optionally
available as marking insert (plug-in, exchangeable) or marking label.
Terminal designs include blade terminals, screw terminals or wire
wrap terminals. Optionally available with auxiliary contact.
US patent number: US 7,038,562 B1
1
Typical application
9510-...
9510-... with
auxiliary contact
Flight Simulators
Ordering information
Technical data
Type
9510
No.
switch with magnetic instantaneous trip for flight simulators
Mounting method and style
G threadneck mounting with standard push button
Threadneck design
1 M12x1x6.3
2 7/16-32UNx6.3
Number of poles
1 single pole
Accessories for threadneck
2 hex nut M12x1, aluminium, serrated lock washer ø12.1/ø17.2, fitted
3 hex nut 7/16-32UN, aluminium,
serrated lock washer 11.3/14.9, fitted
Terminal configuration
J screw terminals with inch thread
1 6-32UNC-2B, silver plated bent 45° inwards
3 6-32UNC-2B, silver plated, with socket, bent 45° inwards
P blade terminals
1 A6.3x0.8 DIN 46244, silver plated
W wire wrap terminal
4 pin size 1.2x1.2 EN 60352-1, gold plated, with socket
Rated voltage
F0 DC 24 V
F1 DC 28 V
Accessories (terminal screws)
B Phillips screw 6-32UNC-2Ax4.8 fitted
(MS 51957-25)
Z without accessories
Accessories (terminal washers)
0 without accessories
2 3.6 split washer fitted (MS 35338-136)
Internal circuit
R2 with logic diode
Colour of the push button
S black
A green, for marking insert
B black, for marking insert
0 without marking
1 hot-stamped marking, can be
read when locating pin is
above
9 without marking insert
Auxiliary contact versions:
blank: no auxiliary
contact (standard)
S1 with auxiliary contact
(female contact for male
contacts to EN 3155-016
M2018)
S5 with polarized auxiliary
contact (female contact
for male contacts to EN
3155-016 M2018)
Current ratings
0.5...150 A
Voltage rating (Other
voltage ratings upon
request)
DC 24 V
DC 28 V
Trip current
< 170 mA
< 200 mA
Trip time
< 25 ms
< 25 ms
Min. switching voltage
at +23 °C/+73.4 °F
at +60 °C/+140 °F
DC 22 V
DC 24 V
DC 25 V
DC 28 V
Internal resistance
approx. 153 Ω
approx. 153 Ω
Rated voltage
auxiliary circuit
DC 28 V / AC 5 V (400 Hz)
Rated load,
auxiliary circuit
at DC 28 V
at DC 28 V
at AC 5 V (400 Hz)
at DC 5 V
Typical life
without auxiliary contact:
10 000 operations at rated voltage
with auxiliary contact:
5 000 operations at rated voltage
Temperature range
-30 °C ...60 °C (-22...+140 °F)
Insulation resistance
> 100 MΩ (DC 500 V)
Dielectric strength
(leakage current < 1mA)
AC 1500 V m
ain terminal to main
terminal, main circuit open
AC 800 V terminal to terminal,
auxiliary circuit open
AC 1500 V m
ain circuit to main circuit
Degree of protection
(IEC 60529)
operating area IP40
terminal area IP00
Vibration (sinusoidal)
x axis, y axis:
3 g (57-500 Hz), +-0.23 mm (10-57 Hz)
to DIN IEC 60068-2-6, test Fc
10 cycles/frequency axis
z axis:
2 g (57-500 Hz), +-0.23 mm (10-57 Hz)
Shock
5 g (11 ms),
to DIN IEC 60068-2-27, test Ea
Humidity
240 hours at 95 % RH, 40 °C
to DIN IEC 60068-2-3, test Ca
Mass
23 g without accessories
26 g with accessories
approx. 27 g with auxiliary contact,
without accessories
approx. 30 g with auxiliary contact,
with accessories
9510 - G 2 1 3 - J 1 F1 - B 0 R2 S 1 - S1 - 5 A ordering example
Please be informed that we have minimum ordering quantities to be
observed.
2010
0,5 A resistive
0,2 A lamp load
0,24 A lamp load
0,005 A minimum load
www.e-t-a.de
1
Dimensions
Other main terminal designs
-P1…
black or
green
3.5
.138
white
hex nut
lock washer
14.2
.559
6.8
.268
locating pin
19.5
.768
6.3
.248
terminal screw
6-32UNC-2A x 4.8/.189
(MS 51957-25)
with lock washer
10
(MS 35338-136)
plug-in/pull-out terminal
.394
module (max. 10 times)
tightening torque max. 1 Nm
15 45°
.591
8
.315
-W4…
15.6
.614
3.6
.142
8
.315
12.7
.500
mounting holes
wire wrap pin 1.2 x 1.2 /.047 x .047
EN 60352-1
1.2
.047
10
.394
ø3.2+0.15
.126+.006
Internal connection diagram
9.5±0.2
.374±.008
9.5
.374
.492+.008 (M12x1)
.453+.008 (7/16-32)
terminal screw
(MS 51957-25)
with lock washer (MS 35338-136)
plug-in terminals
tightening torque:
max. 0.8 Nm factory mounted
max. 0.4 Nm mounted by customer
ø12.5+0.2 (M12x1)
ø11.5+0.2 (7/16-32)
x1 )
12 -32
(M 7/16
4
1 7(
SW 12.
SW
17
.669
-J3…
2
15 45°
.591
blade terminal
DIN 46244-A6.3-0.8 (QC .250)
plug-in terminals
42.7
1.68
47.5
1.87
.2 9
ax 07
m ax .
m
I LINE
9.5
.374
ø8.4
.331
1.5
.059
1
ø10
.394
. 2 79
ax .0
m ax
m
6.35
.250
2.5
.098
13 ON
.512
tightening torque max. 3.5 Nm
M12x1 or
7/16-32UN-2A THD
18.5 OFF
.728
9510-G…-J1..-B2....
current rating in A
thickness 1.5 - 3 mm
.059 - .118 in.
internal circuit R 2
2
9510-G…-J1..-B0....-S1...
9510 with auxiliary contact
16,2±0,5
line I
auxiliary contact,
female contact for
male contacts to
EN 3155-016 M2018
max. 6,5
19,5
2
14,2
with polarized auxiliary contact
12
2
11
LINE 1
3
All standard terminal
options are available
with Auxiliary Contact
version.
Other dimensions see type 9510
LINE 1
5
y
x
z
This is a metric design and millimeter dimensions take precedence ( mm )
inch
2
www.e-t-a.de
2010
Accessories
Label (black) for push/pull button (S0)
Splash cover/hex nut assembly with O ring (IP66 and IP67)
(approved to VG 95345, part 23)
X 200 801 03 matt black finish nut M12x1x1.8, black cover
X 200 801 08 nickel plated nut M12x1x1.8, transparent cover
X 200 801 09 matt black finish nut 7/16-32x1x1.8, black cover
X 200 801 10 matt black finish nut 7/16-32x1x1.8,
transparent cover
X 200 801 12 with blackened nut and transparent cover
Part number
0.5
Y 307 082 01
1/2
Y 307 082 02
1
Y 307 082 03
1.5
Y 307 082 04
1 1/2
Y 307 082 05
2
Y 307 082 06
2.5
Y 307 082 29
2 1/2
Y 307 082 30
3
Y 307 082 07
3 1/2
Y 307 082 31
4
Y 307 082 35
Actuator extension (black) to be fitted on the push button
(approved to VG 95345, T23)
X 200 803 01
5
Y 307 082 08
ø20
ø.787
5.5
Y 307 082 33
6
Y 307 082 17
7.5
Y 307 082 09
7 1/2
Y 307 082 10
10
Y 307 082 11
15
Y 307 082 12
17
Y 307 082 34
Y 307 082 13
25
Y 307 082 14
30
Y 307 082 15
35
Y 307 082 16
40
Y 307 082 18
50
Y 307 082 19
60
Y 307 082 20
70
Y 307 082 21
75
Y 307 082 22
80
Y 307 082 23
90
Y 307 082 24
100
Y 307 082 25
120
Y 307 082 26
125
Y 307 082 27
150
Y 307 082 28
R
Y 307 082 32
1
.071
1.8
Rated current (A)
17
.669
M12x1 or
7/16-32
Identification collar to be snapped on the push button
Y 307 004 01 black
Y 307 004 02 white
Y 307 004 03 red
Y 307 004 04 green
Y 307 004 05 blue
6.4
.252
ø14
.551
ø6.85
.270
ø12.35
.486
0.65
.026
Lock out ring to block the push button in OFF position
Y 307 005 01 red
Y 307 005 02 black
ø14.6
.575
7.7
.303
Plug-in screw terminal,
bent at 45° inwards (2 pcs needed per unit)
Y 307 187 02 terminal silver plated
Y 304 508 02 Phillips screw 6-32 UNC-2Ax4.8 (MS 51957-25)
Y 304 509 01 split washer (MS 35338-136)
ø10.9
.429
Plug-in blade terminal (2 pcs needed per unit)
Y 307 202 02 P10 terminal silver plated
0.8
.031
Plug-in/pull-out screw terminals with socket,
bent at 45° inwards
X 222 173 11 terminals silver plated
Plug-in/pull-out wire wrap terminals with socket
X 222 174 12 terminals gold plated
2010
inch
www.e-t-a.de
3
Accessories
Hex nut M12x1
Y 300 116 04
Hex nut 7/16-32
Y 304 506 03
hot stamped
current rating (A)
black
green
without
Y 307 280 01
Y 307 280 02
1/4
X 222 175 35
X 222 176 35
0.5
X 222 175 01
X 222 176 01
1/2
X 222 175 02
X 222 176 02
0.75
X 222 175 41
X 222 176 41
3/4
X 222 175 36
X 222 176 36
Toothed washer Ø11.3 / Ø14.9 (MS 35333-141)
Y 304 507 01
1
X 222 175 03
X 222 176 03
1.5
X 222 175 04
X 222 176 04
Front plate with mounting thread 6-32UNC-2B
for threadneck 7/16-32UN
Y 301 516 21
1 1/2
X 222 175 05
X 222 176 05
2
X 222 175 06
X 222 176 06
2.5
X 222 175 29
X 222 176 29
Threaded sleeve
Y 307 281 04
2 1/2
X 222 175 30
X 222 176 30
3
X 222 175 07
X 222 176 07
Extracting tool of marking insert
Y 307 301 01
3.5
X 222 175 33
X 222 176 33
3 1/2
X 222 175 34
X 222 176 34
4
X 222 175 32
X 222 176 32
5
X 222 175 08
X 222 176 08
6
X 222 175 17
X 222 176 17
7
X 222 175 31
X 222 176 31
7.5
X 222 175 09
X 222 176 09
7 1/2
X 222 175 10
X 222 176 10
8
X 222 175 37
X 222 176 37
10
X 222 175 11
X 222 176 11
14
X 222 175 38
X 222 176 38
15
X 222 175 12
X 222 176 12
X 222 175 13
X 222 176 13
24
X 222 175 42
X 222 176 42
25
X 222 175 14
X 222 176 14
30
X 222 175 15
X 222 176 15
35
X 222 175 16
X 222 176 16
40
X 222 175 18
X 222 176 18
45
X 222 175 39
X 222 176 39
50
X 222 175 19
X 222 176 19
60
X 222 175 20
X 222 176 20
70
X 222 175 21
X 222 176 21
75
X 222 175 22
X 222 176 22
80
X 222 175 23
X 222 176 23
90
X 222 175 24
X 222 176 24
100
X 222 175 25
X 222 176 25
120
X 222 175 26
X 222 176 26
125
X 222 175 27
X 222 176 27
150
X 222 175 28
X 222 176 28
R
X 222 175 40
X 222 176 40
Lock washer Ø12 / Ø15
Y 300 118 03
Serrated lock washer Ø12.1 / Ø17.2
Y 302 911 01
1
Marking inserts (push button configuration A or B)
All dimensions without tolerances are for reference only. In the interest of improved design,
performance and cost effectiveness the right to make changes in these specifications
without notice is reserved.Product markings may not be exactly as the ordering codes.
Errors and omissions excepted.
4
www.e-t-a.de
2010
