9510-G213-J3F1-B2R2B1-125A
    E-T-A
9510-G213-J3F1-B2R2B1-125A 数据手册
Simulator switch, magnetic operation 9510-... Description Single pole, magnetic simulator switch with extremely low trip current and precise trip behavior. Available with threadneck mounting or flange mounting. Actuation is via a push-pull mechanism. Push button marking for simulation of various current ratings is optionally available as marking insert (plug-in, exchangeable) or marking label. Terminal designs include blade terminals, screw terminals or wire wrap terminals. Optionally available with auxiliary contact. US patent number: US 7,038,562 B1 1 Typical application 9510-... 9510-... with auxiliary contact Flight Simulators Ordering information Technical data Type 9510 No. switch with magnetic instantaneous trip for flight simulators Mounting method and style G threadneck mounting with standard push button Threadneck design 1 M12x1x6.3 2 7/16-32UNx6.3 Number of poles 1 single pole Accessories for threadneck 2 hex nut M12x1, aluminium, serrated lock washer ø12.1/ø17.2, fitted 3 hex nut 7/16-32UN, aluminium, serrated lock washer 11.3/14.9, fitted Terminal configuration J screw terminals with inch thread 1 6-32UNC-2B, silver plated bent 45° inwards 3 6-32UNC-2B, silver plated, with socket, bent 45° inwards P blade terminals 1 A6.3x0.8 DIN 46244, silver plated W wire wrap terminal 4 pin size 1.2x1.2 EN 60352-1, gold plated, with socket Rated voltage F0 DC 24 V F1 DC 28 V Accessories (terminal screws) B Phillips screw 6-32UNC-2Ax4.8 fitted (MS 51957-25) Z without accessories Accessories (terminal washers) 0 without accessories 2 3.6 split washer fitted (MS 35338-136) Internal circuit R2 with logic diode Colour of the push button S black A green, for marking insert B black, for marking insert 0 without marking 1 hot-stamped marking, can be read when locating pin is above 9 without marking insert Auxiliary contact versions: blank: no auxiliary contact (standard) S1 with auxiliary contact (female contact for male contacts to EN 3155-016 M2018) S5 with polarized auxiliary contact (female contact for male contacts to EN 3155-016 M2018) Current ratings 0.5...150 A Voltage rating (Other voltage ratings upon request) DC 24 V DC 28 V Trip current < 170 mA < 200 mA Trip time < 25 ms < 25 ms Min. switching voltage at +23 °C/+73.4 °F at +60 °C/+140 °F DC 22 V DC 24 V DC 25 V DC 28 V Internal resistance approx. 153 Ω approx. 153 Ω Rated voltage auxiliary circuit DC 28 V / AC 5 V (400 Hz) Rated load, auxiliary circuit at DC 28 V at DC 28 V at AC 5 V (400 Hz) at DC 5 V Typical life without auxiliary contact: 10 000 operations at rated voltage with auxiliary contact: 5 000 operations at rated voltage Temperature range -30 °C ...60 °C (-22...+140 °F) Insulation resistance > 100 MΩ (DC 500 V) Dielectric strength (leakage current < 1mA) AC 1500 V m  ain terminal to main terminal, main circuit open AC 800 V terminal to terminal, auxiliary circuit open AC 1500 V m  ain circuit to main circuit Degree of protection (IEC 60529) operating area IP40 terminal area IP00 Vibration (sinusoidal) x axis, y axis: 3 g (57-500 Hz), +-0.23 mm (10-57 Hz) to DIN IEC 60068-2-6, test Fc 10 cycles/frequency axis z axis: 2 g (57-500 Hz), +-0.23 mm (10-57 Hz) to DIN IEC 60068-2-6, test Fc 10 cycles/frequency axis Shock 5 g (11 ms), to DIN IEC 60068-2-27, test Ea Humidity 240 hours at 95 % RH, 40 °C to DIN IEC 60068-2-3, test Ca Mass 23 g without accessories 26 g with accessories approx. 27 g with auxiliary contact, without accessories approx. 30 g with auxiliary contact, with accessories 9510 - G 2 1 3 - J 1 F1 - B 0 R2 S 1 - S1 - 5 A ordering example Please be informed that we have minimum ordering quantities to be observed. 2010 0,5 A resistive 0,2 A lamp load 0,24 A lamp load 0,005 A minimum load www.e-t-a.de 1 Simulator switch, magnetic operation 9510-... Dimensions Other main terminal designs -P1… black or green 3.5 .138 white hex nut lock washer 14.2 .559 6.8 .268 locating pin 19.5 .768 6.3 .248 terminal screw 6-32UNC-2A x 4.8/.189 (MS 51957-25) with lock washer 10 (MS 35338-136) plug-in/pull-out terminal .394 module (max. 10 times) tightening torque max. 1 Nm 15 45° .591 8 .315 -W4… 15.6 .614 3.6 .142 8 .315 12.7 .500 mounting holes wire wrap pin 1.2 x 1.2 /.047 x .047 EN 60352-1 plug-in/pull-out terminal module (max. 10 times) 1.2 .047 10 .394 ø3.2+0.15 .126+.006 Internal connection diagram 9.5±0.2 .374±.008 9.5 .374 .492+.008 (M12x1) .453+.008 (7/16-32) terminal screw 6-32UNC-2A x 4.8/.189 (MS 51957-25) with lock washer (MS 35338-136) plug-in terminals tightening torque: max. 0.8 Nm factory mounted max. 0.4 Nm mounted by customer ø12.5+0.2 (M12x1) ø11.5+0.2 (7/16-32) ) x1 ) 12 -32 (M 7/16 4 1 7( SW 12. SW 17 .669 -J3… 2 15 45° .591 blade terminal DIN 46244-A6.3-0.8 (QC .250) plug-in terminals 42.7 1.68 47.5 1.87 .2 9 ax 07 m ax . m I LINE 9.5 .374 ø8.4 .331 1.5 .059 1 ø10 .394 . 2 79 ax .0 m ax m 6.35 .250 2.5 .098 13 ON .512 tightening torque max. 3.5 Nm M12x1 or 7/16-32UN-2A THD 18.5 OFF .728 9510-G…-J1..-B2.... current rating in A thickness 1.5 - 3 mm .059 - .118 in. internal circuit R 2 2 - 9510-G…-J1..-B0....-S1... 9510 with auxiliary contact 16,2±0,5 line I auxiliary contact, female contact for male contacts to EN 3155-016 M2018 max. 6,5 19,5 + with auxiliary contact 2 14,2 - with polarized auxiliary contact 12 2 11 LINE 1 - 3 All standard terminal options are available with Auxiliary Contact version. Other dimensions see type 9510 without auxiliary contact LINE 1 + + 5 y x z This is a metric design and millimeter dimensions take precedence ( mm ) inch 2 www.e-t-a.de 2010 Simulator switch, magnetic operation 9510-... Accessories Label (black) for push/pull button (S0) Splash cover/hex nut assembly with O ring (IP66 and IP67) (approved to VG 95345, part 23) X 200 801 03 matt black finish nut M12x1x1.8, black cover X 200 801 08 nickel plated nut M12x1x1.8, transparent cover X 200 801 09 matt black finish nut 7/16-32x1x1.8, black cover X 200 801 10 matt black finish nut 7/16-32x1x1.8, transparent cover X 200 801 12 with blackened nut and transparent cover Part number 0.5 Y 307 082 01 1/2 Y 307 082 02 1 Y 307 082 03 1.5 Y 307 082 04 1 1/2 Y 307 082 05 2 Y 307 082 06 2.5 Y 307 082 29 2 1/2 Y 307 082 30 3 Y 307 082 07 3 1/2 Y 307 082 31 4 Y 307 082 35 Actuator extension (black) to be fitted on the push button (approved to VG 95345, T23) X 200 803 01 5 Y 307 082 08 ø20 ø.787 5.5 Y 307 082 33 6 Y 307 082 17 7.5 Y 307 082 09 7 1/2 Y 307 082 10 10 Y 307 082 11 15 Y 307 082 12 17 Y 307 082 34 20 Y 307 082 13 25 Y 307 082 14 30 Y 307 082 15 35 Y 307 082 16 40 Y 307 082 18 50 Y 307 082 19 60 Y 307 082 20 70 Y 307 082 21 75 Y 307 082 22 80 Y 307 082 23 90 Y 307 082 24 100 Y 307 082 25 120 Y 307 082 26 125 Y 307 082 27 150 Y 307 082 28 R Y 307 082 32 1 .071 1.8 Rated current (A) 17 .669 M12x1 or 7/16-32 Identification collar to be snapped on the push button Y 307 004 01 black Y 307 004 02 white Y 307 004 03 red Y 307 004 04 green Y 307 004 05 blue 6.4 .252 ø14 .551 ø6.85 .270 ø12.35 .486 0.65 .026 Lock out ring to block the push button in OFF position Y 307 005 01 red Y 307 005 02 black ø14.6 .575 7.7 .303 Plug-in screw terminal, bent at 45° inwards (2 pcs needed per unit) Y 307 187 02 terminal silver plated Y 304 508 02 Phillips screw 6-32 UNC-2Ax4.8 (MS 51957-25) Y 304 509 01 split washer (MS 35338-136) ø10.9 .429 Plug-in blade terminal (2 pcs needed per unit) Y 307 202 02 P10 terminal silver plated 0.8 .031 Plug-in/pull-out screw terminals with socket, bent at 45° inwards X 222 173 11 terminals silver plated Plug-in/pull-out wire wrap terminals with socket X 222 174 12 terminals gold plated 2010 This is a metric design and millimeter dimensions take precedence ( mm ) inch www.e-t-a.de 3 Simulator switch, magnetic operation 9510-... Accessories Hex nut M12x1 Y 300 116 04 Hex nut 7/16-32 Y 304 506 03 hot stamped current rating (A) black green without Y 307 280 01 Y 307 280 02 1/4 X 222 175 35 X 222 176 35 0.5 X 222 175 01 X 222 176 01 1/2 X 222 175 02 X 222 176 02 0.75 X 222 175 41 X 222 176 41 3/4 X 222 175 36 X 222 176 36 Toothed washer Ø11.3 / Ø14.9 (MS 35333-141) Y 304 507 01 1 X 222 175 03 X 222 176 03 1.5 X 222 175 04 X 222 176 04 Front plate with mounting thread 6-32UNC-2B for threadneck 7/16-32UN Y 301 516 21 1 1/2 X 222 175 05 X 222 176 05 2 X 222 175 06 X 222 176 06 2.5 X 222 175 29 X 222 176 29 Threaded sleeve Y 307 281 04 2 1/2 X 222 175 30 X 222 176 30 3 X 222 175 07 X 222 176 07 Extracting tool of marking insert Y 307 301 01 3.5 X 222 175 33 X 222 176 33 3 1/2 X 222 175 34 X 222 176 34 4 X 222 175 32 X 222 176 32 5 X 222 175 08 X 222 176 08 6 X 222 175 17 X 222 176 17 7 X 222 175 31 X 222 176 31 7.5 X 222 175 09 X 222 176 09 7 1/2 X 222 175 10 X 222 176 10 8 X 222 175 37 X 222 176 37 10 X 222 175 11 X 222 176 11 14 X 222 175 38 X 222 176 38 15 X 222 175 12 X 222 176 12 20 X 222 175 13 X 222 176 13 24 X 222 175 42 X 222 176 42 25 X 222 175 14 X 222 176 14 30 X 222 175 15 X 222 176 15 35 X 222 175 16 X 222 176 16 40 X 222 175 18 X 222 176 18 45 X 222 175 39 X 222 176 39 50 X 222 175 19 X 222 176 19 60 X 222 175 20 X 222 176 20 70 X 222 175 21 X 222 176 21 75 X 222 175 22 X 222 176 22 80 X 222 175 23 X 222 176 23 90 X 222 175 24 X 222 176 24 100 X 222 175 25 X 222 176 25 120 X 222 175 26 X 222 176 26 125 X 222 175 27 X 222 176 27 150 X 222 175 28 X 222 176 28 R X 222 175 40 X 222 176 40 Lock washer Ø12 / Ø15 Y 300 118 03 Serrated lock washer Ø12.1 / Ø17.2 Y 302 911 01 1 Marking inserts (push button configuration A or B) All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 4 www.e-t-a.de 2010
9510-G213-J3F1-B2R2B1-125A 价格&库存
很抱歉,暂时无法提供与“9510-G213-J3F1-B2R2B1-125A”相匹配的价格&库存,您可以联系我们找货
